(1) 2 3 »
are car, ute, and sedan leaves the same?
From Christchurch NZ
I need to know if they use the same leaves.
Mine have been reset by a former owner, and I need to raise it back up a bit to squeeze more rubber under the guards.
Posted on: 2006/11/11 4:13
Forced Induction!
Re: are car, ute, and sedan leaves the same?
i think sedans are the same as coupe and the ute and wagons are the same. they have the extra load spring.
Posted on: 2006/11/11 8:17
From Launceston, Tasmania
I would have to guess and say that the utes would be stronger as to hold loads, so therefore they may have an extra leaf or 2.
Posted on: 2006/11/11 17:17
From Melbourne AUS
4 leaf rear standard in utes..
im pretty sure coupes/sedans had 3??
not sure about wagons though
Posted on: 2006/11/11 18:48
1973 B110 A12
4 in the wagons
Posted on: 2006/11/11 18:52
def 3 in sedans, i added the tiny bottom one off a 120y when doing my borg warner conversion
Posted on: 2006/11/11 19:50
so coupe ones will fit a sedean then?
Posted on: 2006/11/12 10:48
Forced Induction!
Looks like you maybe coming down my way to get the coupe ones.........
Posted on: 2006/11/16 17:36
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
From Geelong, Vic
they are all interchangable, just wagon and utes have a load spring
Posted on: 2006/11/16 19:12
From Cape Town ZA
They do, I'll be fitting UTE leaves to my 1200 sedan tonight. They are much stronger, and will help stop the axle flipping over backwards. That'll be useful if I end up making the power I'm aiming for. Will take some piccys and post tomorrow.
Posted on: 2006/11/16 21:06
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
(1) 2 3 »
