Tyrie wrote:
see i dunno, Dodgeman's sources say you can fit a tyre to a wider rim if its a lower profile, that doesnt make sense to me, perhaps Dodgeman can explain it for me?
I know not why tyres that are 60 profile or lower are both legal & [presumably] safe on a rim that is 1/2" wider than the spec for the same width tyre that has a larger aspect ratio. [If the tyre is a 275 or wider, then the 60 series & lower has a 1" wider allowance]
The info I have quoted was gleaned from my copy of the 'Tyre & Rim Association of Australia Standards Manual'
Mine is an older copy, but I do not believe that things have changed much.
I must admit that I thought I would be universally dumped on again for holding this view, but I am heartilly cheered by the fact that there more than a few members who hold the view that there is a practical & safe limit to these things & going past this limit is both risky & often unlawfull.
I thank you for your support.
Cheater_5 I did not mean to sound as if I was picking on you & I appologise if you felt that way, however your new wheels & tyres were an obvious illustration of a point.
Your 175 tyres are legal in Australia on rims as wide as 7" if they are 60 profile or lower. The problem I have is with 'overstretched' tyres. Steel belt radials have this woven band of steel to keep the tread where it should be, but when the sidewalls are stretched too far, it imparts a stress on the junction of belt & sidewall that the tyre is not designed to handle & this can easily bring about serious problems in the inner construction of the tyre at this point.
By sticking to the recomended or permitted rim widths you can still achieve the look that is wanted, albeit in moderation, while retaining the safety features that have been designed into the tyre right from the start.
The appearance of the finished product is in the eye of the beholder & my particular view does not see 'overstretched' tyres in a good light. That's just my opinion.
The picture shows a 205x60x13 tyre on a 5-1/2" rim. As can be seen, it sits well enough without excessive bag & provides a reasonably comfy ride. [Very important at my age
] I chose this size for its diameter in an attempt to address an undergearing problem & these were the largest practical size for the 1000 sedan that they were under.
The fronts are 185x60x13 on the same rim. The difference with a 5" rim will hardly be noticed, but it will weigh less & allow the tyre to do its thing as the maker intended.
