SR20 > H165???
I'm doing a Sr2oDet into a 120y and was wondering how long the H165 would last. Should I do a hilux/R31 swap now and save the worry or will it last a short time if I take it easy on it????
Posted on: 2007/1/30 9:51
Re: SR20 > H165???
From Newscastle, Australia
do the swap now otherwise youll be up for the expense of fabricating another tailshaft, plus the rear track of the H165 is alot narrower than a cut down bigger diff
Posted on: 2007/1/30 9:55
Dont die wondering.....
Re: SR20 > H165???
From Sydney, Australia
200hp will last several race seasons if you don't do burnouts on Sydney roads. So <12psi boost on the sr20det will be fine. It's depends on what your definition of 'taking it easy is' .
Sydney roads are full of potholes and dangerous bumps, which are diff's enemy.
I'd recommend you doing the R31 now though, because it will mean having a second tailshaft made up if you do it later.
Posted on: 2007/1/30 9:57
Re: SR20 > H165???
From campbelltown (sydney) australia
i agree, do it now. the h165 will last a while i gave mine heaps with my ca18 with 205 tread and it didnt snap even after wasting a whole two tyres. no matter how much ppl say they will take it easy, once its running i guarantee ull wanna flog the guts out of it.
Posted on: 2007/1/30 10:06
* caution, sunglasses must be worn to view my ca18det *
Re: SR20 > H165???
Good point.
Anyone have any links that can help me out with the motor conversion????
Posted on: 2007/1/30 10:11
Re: SR20 > H165???
Not too shy to talk
From rocky qld aust
i only had worked a14 in our s/wag & done 3 std boxes 1 heavy duty 4sp & it ate h165's for brekky & i lost count on how many TAILSHAFTS...was going to put shell on suzuki chassis but after getting involved on this site changed my mind...i picked up this week a a15 with slight mods[i will go full house on this one just to see how much N.A HP I CAN GET] i already have a alloy 5sp celica box.i will be fitting a SIGMA SCORPION disc brake rear end in mine& see how that holds up.
Posted on: 2007/2/10 5:25
"white lighting"
