Good point jog before you run
Seriously pulling anything apart is an easy task, you have to make sure you know what you are getting into.
Datoman 1000 has a great engine which with the right turbo, intercooler and tuned straight gas system could easily see 300hp.
The Ca18et more compact than the z18et which george fury raced.
For a more weird setup but will fit easily with a supra box and adapter would be a Taunus or Saab V4 1.8 litre 60 degree pushrod 94kgs but mated with a v6 vortex mitsubishi supercharger.
and . . . . .
if you go L series the L20b is 20mm taller than the l16 but!!! with the shorter head of the 12 valve ka24e head 34mm inlet valves!!!! it will be as tall as an l16. However a bored out l18 should suffice and has the same height as the l16 but 1991cc is possible and more with prepped l20b crank and shorter custom pistons.
190rwkw with a common cheap small rx7 snail can be had if you follow the following link.
http://zac510.ozdat.com/This hybrid L series and Ka can run no pollution gear, dizzie is in the right spot, 5 speeds everywhere and more.
Also should be lighter than an SR20DE all up by at least 10-20kg, even more with a lightened crank and quad bike carbs like josh has in okinawa.
