« 1 (2)
Re: Starter motor price
From Adelaide, Australia
My starter motor packed in finally so I rang up Repco for a price on one, thinking $70 or so dollars woudl be resaonable. They got back to me with a price of $295!!
But you know what repco stands for?
Rip Every Poor C**t Off.
Supercheap auto had starters on sale last year, I picked up a L-series one for $35
Posted on: 2007/2/21 12:16
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Bunbury Western Australia
bugger I need one too now, sounds like the battery is flat but it is a near new 770cca battery with all new cables, clamps and is showing full charge, the starter motor has been sounding a bit crook for a while now so I spose I should have been expecting it, just sux it happened at all
Posted on: 2007/2/26 1:47
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
phwoaar just got a price from Coventry's $270 for an A12 starter motor!!
Is there any difference between the A12, A14 or A15 starter motors?
Posted on: 2007/2/26 4:54
I don't suppose this would fit?
http://cgi.ebay.com.au/Starter-Motor- ... ViewItem#ebayphotohosting
quite cheap for a new starter just not sure if 80-82 model pulsars used A series engines?
Posted on: 2007/2/26 8:54
woohoo, guess what!
It fit the 80-82 model pulsar starter motor is a direct A series replacement!
Part number was JSX119 from memory, it cost me $36 from ebay to my door brand spankin new
N.O.S. item was just gathering dust, one mans trash is anothers treasure eh!
Posted on: 2007/3/8 2:12
From Townsville, Qld
I can tell you what doesn't work now that the darn thing burnt out...
GA16DE/QG18DE starter motors from N14/15/16 Pulsars need modification to fit (relief of some external ribbing and drilling out threaded bolt hole to match the M10 shank). Thought I could get away with it for $70 but after countless cranking both with and without compression it's dying and getting too hot to crank.
Posted on: 2019/4/27 3:07
yeah the 1980 Pulsar comes with a-series engine, so that will fit a 1200
Possibly the QG starter may have fit too tight on the flywheel leading to overheating. OR, since that's a small permanent-magnet starter, maybe they don't hold up to extended cranking
Posted on: 2019/4/27 23:02
There were some questions in this topic
A12/A14/A15 starters are the same. However in different years there are differences
* Mitsubishi vs Hitachi
* Starting July 1971, Automatic used high-torque (prior to that, automatics used the same starter as manuals)
1979-1980 N10 (Pulsar/310) uses an A-series engine. In 1981 N10 changed to E-series
a-series starters today and noticed that some had 8 teeth and some had 9. I thought all starters were interchangable, so does different ring gear/flywheel size on a12-a15 overcome the extra tooth
Ring gear is the same on A12,A14 and A15. Unknown what the 8-tooth gear is from. The ones I've seen are 9-tooth
And there was this report a few years ago: The (larger) Pulsar starter has a notch that wont allow them to go in the 1200. Is this due to RWD vs FWD transmissions or something else? Unknown
jpg  23312-10600.jpg (105.42 KB)
174_5cc61974b5af1.jpg 1024X768 px
Posted on: 2019/4/28 22:14
OK, found some more info:
* The 8-tooth starter gear is from N10 Pulsar/310 front-wheel-drive starter for A14 engine
* Found some photos of starter housing fouling on the the block (even though they bolt to the gearbox)
* The QG/GA/B14 starter is a permanent-magnet type and so they say...
-- if you knock it with a hammer you can crack the magnets
-- if it overheats it weakens the magnets
jpg  starter-to-block interference.jpg (55.81 KB)
174_5cc6c0001c22c.jpg 375X500 px
jpg  starter on block _.jpg (174.74 KB)
174_5cc6c0cf862eb.jpg 1280X960 px
jpg  starter on block _.jpg (185.42 KB)
174_5cc6c10042eb2.jpg 1280X960 px
jpg  Hitachi S114-800-QG13DE.jpg (50.60 KB)
174_5cc6c13b14db0.jpg 800X600 px
jpg  Hitachi S114-800 B14 2002.jpg (48.29 KB)
174_5cc6c14888590.jpg 800X600 px
jpg  Hitachi S114-800 nose (Nissan 23300-0M302).jpg (19.85 KB)
174_5cc6c153d445d.jpg 300X300 px
Posted on: 2019/4/29 10:18
« 1 (2)
