There were some questions in this topic
Is there any difference between the A12, A14 or A15 starter motors?
A12/A14/A15 starters are the same. However in different years there are differences
* Mitsubishi vs Hitachi
* Starting July 1971, Automatic used high-torque (prior to that, automatics used the same starter as manuals)
80-82 model pulsar starter motor is a direct A series replacement
1979-1980
N10 (Pulsar/310) uses an A-series engine. In 1981 N10 changed to E-series
a-series starters today and noticed that some had 8 teeth and some had 9. I thought all starters were interchangable, so does different ring gear/flywheel size on a12-a15 overcome the extra tooth
Ring gear is the same on A12,A14 and A15. Unknown what the 8-tooth gear is from. The ones I've seen are 9-tooth
And there was this report a few years ago: The (larger) Pulsar starter has a notch that wont allow them to go in the 1200. Is this due to RWD vs FWD transmissions or something else? Unknown
