« 1 (2)
Re: Spring rates... what do you use?
for daily driving 250's may be a little heavy for an A series engine. if your roads are nice and smooth and the corners are all cambered well then it'd be great ... most aren't tho and you'll find the front of the car might be more likely to bounce over bumpsand skip thru rough corners .... heavier rate isn't always better when it comes to a daily, i know i'd be long over my setup by now if i drove it more than a couple times a month
Posted on: 2007/2/25 7:38
From Brisbane
Im going to use the same as you boof 175pd springs. You want a good balance for a streeter. Its just like a Cam you dont go all out for street you compromise, 250 for a series is bit too much i would think too.
Posted on: 2007/2/25 7:47
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Gold Coast Australia
This is for the CA guys, I haven't yet been to any suspension shops to enquire as thats a couple of months away, but would I be best using a similar spring rate for my SR powered sunny? Taking into consideration that the SR is heavier and that my car is quite a bit heavier than a 1200 to begin with.
If you guys seem to be using around 225 - 275, should I be looking at around 275 - 325? I thought I would ask now so I dont go to pedders or where ever and seem like a dumbass.
Cheers Mitchell
Posted on: 2007/2/25 10:22
SR20DET Sunny for sale, click me for details
From Adelaide, SA the drift state
180lb with 230 high in coilovers.
Posted on: 2007/2/26 2:55
From Adelaide, Australia
275lbx180mmx63mm King springs up front, rear leafs 20% stiffer with koni reds all round.
Edit: should probably mention not for the road and with the slightly heavier L16.
Posted on: 2007/2/26 3:00
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Brisbane
i'm running 6kg HKS coil overs in mine
Posted on: 2007/2/26 3:07
From Christchurch NZ
Don't go too hard Chris. Damon has 910 springs, and he hates them.
Dave, (B110SSS) swears by avenger rear coils. Reckons the spring rate is perfect.
Posted on: 2007/2/26 4:05
Forced Induction!
From Adelaide, South Australia
What are stock springs 120lb ?
Posted on: 2007/2/26 8:57
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
« 1 (2)
