Removing step from rear arch on sedan
From Adelaide, Australia
Has anyone removed the rear door step from the rear arch on a sedan and if so how did they go about it? Pics would be great too.
Cheers
Sean
Posted on: 2007/2/28 7:20
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Removing step from rear arch on sedan
What part are you talking about?
Maybe a pic of the area will help out first.
Posted on: 2007/2/28 7:48
From Geelong, Vic
its the indent for the door seal thats is about an inch in from the outside of the rear guard
Posted on: 2007/2/28 7:51
Its this bit circled, but on the inside of the wheel well.
(cheers sikdatto1200 for the photo)
Posted on: 2007/2/28 7:56
IPRA Build
Im not sure if I am on the right track for why you want to remove it. But if its because of rust. I would just clean it up with a linisher and/or a die grinder to get the rust out so you can weld a patch in.
If its rusted underneath too, I would just cut it out with an angle grinder from underneath.
Posted on: 2007/2/28 8:05
From Gold Coast Australia
OAN878 (chris) was telling me at Jambo last year that when he launched hard with the wide wheels on the back of his sedan, the sidewall of the tyre rubbed against this part. I think he would of rectified the problem by now so maybe try giving him a PM, if it is for that reason.
Posted on: 2007/2/28 8:14
SR20DET Sunny for sale, click me for details
Yes thats right, I need more clearance, when I look under the rear wheel well I can see the tyre almost touching without any weight on the car. Also fitting flares but I have the pumping of the lip itself sorted.
Posted on: 2007/2/28 9:03
IPRA Build
From Portland OR. USA
I've removed the step before for tire clearence on a 2 door. If there is space behind the "bump" (there is on the 2 door) just take a ball pean hammer and start at the rear end of the bump where it is small. With lots of hammering and some finnesse you can invert the raised area and gain quite a bit of tire room. Just takes time and makes lots of noise.
Posted on: 2007/2/28 9:15
From adelaide
would there still be enough room for the seal with this mod, im guessing you could gain up to 10mm from this
Posted on: 2007/2/28 18:21
1200 restoration project moving slower than it actually is
From Geelong, Vic
you get almost an inch, dont know about the door seal.....thats sorta why hes asking if anyone has done it i guess
if i can move my spare sedan ill have a go at it with a hammer and see if the door still closes
Posted on: 2007/2/28 19:50
