Borg Worner Diff For Sale
Not too shy to talk
From Gold Coast
I have a Borg Worner Diff out of a VL turbo with LSD. The whole thing is complete less brakes. Come pick it up, make me an offer
PM for inspection
Evey
Posted on: 2007/3/6 21:32
1984 Datsun 1200 Ute with SR20DET- MIN712
Re: Borg Worner Diff For Sale
From Canberra
hmmm 3.45 LSD... will this fit into a skyline diff?
Posted on: 2007/3/6 21:41
From Gold Coast, Australia
into a R31 housing, yes it will.
Posted on: 2007/3/6 22:16
From Sydney, Australia
VL Turbo should be a 3.9:1
Maybe the seller can pop the rear cover and rear the numbers off the crownwheel.
VL Turbo LSDs are normally fried. For obvious reasons.
Posted on: 2007/3/6 23:21
Still a good item though. Worth getting at the right price.
Posted on: 2007/3/6 23:22
Not too shy to talk
From Gold Coast
Hey guys
Diff needs to go, I will let it go cheap. PM for inspection. These diffs are mega strong and quite hard to come by.
Posted on: 2007/3/7 15:21
From Canberra
hmm I was sure they were 3.45:1, but i dont know where that number came from so you may be right dattodude. Do you know what it costs to rebuild one of these or r31 LSDs?
oh and PM sent
Posted on: 2007/3/7 15:59
About 200-400 dollars according to forums. Labour plus shims to retension the springs.
But remember that a little 1200 will have a lower 'LSD break point' required when comparing to a heavy VL turbo. So a worn LSD in a commodore might be fine in a 1200. Get it installed, and rebuild it later if there is a problem with the LSD tension.
Posted on: 2007/3/7 18:28
From Geelong, Vic
3.45 are standard VL gears, thats where you would have got the number from
Posted on: 2007/3/7 18:32
From Canberra
OK so standard VL is 3.45, VLT is 3.9? so VLT is exactly the same as R31 Sillhouette?
Posted on: 2007/3/7 18:50
