reliability of the 1200 engine
From wangaratta vic australia
as im new to owning a datto 120y fastback,i was just wondering how reliable is the engine ect. the car ive got runs like a swiss watch,my datto is slush o matic and when sittn on a 100km/h shes revvn at 4000 rpm , i was just curious in known how long the donk would last for revving at this high engine revs
Posted on: 2007/3/10 23:43
Re: reliability of the 1200 engine
From UK
With regular servicing........ It will probably outlast the car!
Posted on: 2007/3/10 23:49
Capitalization is the difference between "I had to help my uncle Jack off a horse.." and "I had to help my uncle jack off a horse.."
even with regular servicing ,4000rpm @ 100km/h u gota wonder,thats going tong and hammer on the old donk!
Posted on: 2007/3/10 23:53
From Adelaide, South Australia
It will be fine as long as you keep it tuned ect.
The rings will force you to change the engine before anything breaks in it.
You'll find even the timing chain wont get loose.
Posted on: 2007/3/11 1:31
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
The original A12 was designed and tested to run at 4500 rpm all day long.
These are tough little engines. Just be sure to change the oil once in a while to prevent excessive ring wear. The newer A-series don't seem to hold up as well, they are still tough but more likely to start smoking. perhaps they changed the cast-iron specification or ring specification.
Posted on: 2007/3/11 4:50
From Flinders View, QLD
I drove my datto ute from Sydney to Townsville and she sat on 4000 - 4500RPM (trying to keep up with the missus in the XR8) all day long and didnt miss a beat. Still driving it now with no problems 1 year later, Just carry out regular maintainence and servicing and you will have very little to worry about.
Posted on: 2007/3/11 7:25
Just trying to put the bloody puzzel back together
this info sounds good . i ask because i do the odd trip to wangaratta(vic) to newcastle thats about 1500km round trip and there would be nufn worse then to be stuck on the side of the road.
Posted on: 2007/3/11 8:16
From Tamworth, NSW
Alot of things will fail before the engine. Make sure you have a set of fresh points in it, new thermostat, belts, hoses, oil an filter an you will have no probs
Posted on: 2007/3/11 8:21
Project coupe:
Just drive it
From Christ Church, Barbados
Yeah the A12 is real durable. Stick to regular maintenance and it should never skip a beat.
Posted on: 2007/3/11 9:23
