Re: Need to cut King Springs... help!
From adelaide
Just cut half a coil out of them and see how it sits, if its not enough cut another half and that should be plenty, only thing that pisses you off is having to be carefull were you jack the car from or the springs can fall loose and not locate properally. If your carefull you shouldnt have any problems, as long as there is adequate suspension travel. Ive cut the king springs in mine and no problem except it dosnt have enough suspension travel, personally i thought the king springs i got, (lowest heavy duty for stanza) were way too small and soft, they felt like standard, go the gemi springs!
Posted on: 2007/3/20 4:19
1200 restoration project moving slower than it actually is
Subject Poster Date
     Need to cut King Springs... help! Rainz 2007/3/19 9:16
       Re: Need to cut King Springs... help! WARDY 2007/3/19 9:24
       Re: Need to cut King Springs... help! dattodude 2007/3/19 9:25
         Re: Need to cut King Springs... help! WhiteSedan 2007/3/19 9:27
           Re: Need to cut King Springs... help! Rainz 2007/3/19 9:47
             Re: Need to cut King Springs... help! matbighat 2007/3/19 12:08
               Re: Need to cut King Springs... help! sikdatto1200 2007/3/20 4:19
                 Re: Need to cut King Springs... help! Anonymous 2007/3/20 6:49
                   Re: Need to cut King Springs... help! PIGDOG 2007/3/20 19:18
                     Re: Need to cut King Springs... help! matbighat 2007/3/20 20:36
                       Re: Need to cut King Springs... help! ddgonzal 2007/3/20 22:23
                         Re: Need to cut King Springs... help! PIGDOG 2007/3/20 23:52
                           Re: Need to cut King Springs... help! matty 2007/3/22 14:19
                             Re: Need to cut King Springs... help! PIGDOG 2007/3/22 21:44
