F.S. BRAKE/STRUT UPGRADE
From Ballarat Victoria
I`m selling a pair of struts that would make a good upgrade over standard.
- Commodore Calipers, not sure what model.
- Larger vented discs, as new 10"
- Larger diam. short strut tube,360mm(bottom of tube to top of tube/thread)
- Not sure of pad type (90%left)
PRICE: $300.oo
Posted on: 2007/3/22 23:00
VIC DYNO HIRE
Re: F.S. BRAKE/STRUT UPGRADE
From Newcastle
email me a pic champ boostin10flat@hotmail.com
Posted on: 2007/3/22 23:34
From Melbourne Vic
Posted on: 2007/3/22 23:47
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Quite a regular
From Melbourne , Vic
are these shortened stanza struts? and what is the min diamater wheel that you can fit over them?
Posted on: 2007/3/23 0:17
13" wheels would be the smallest wheels that would fit over them, Im not sure what strut/stub is off. Maybe one of the other members will recognise them and add a post??
I took them off a 510 i had. but they are shorter than 510 struts.
They have a narrower caliper bolt spacing than 240K units.
Posted on: 2007/3/23 1:18
VIC DYNO HIRE
Forgot to mention that where the tube is a different colour is where i removed the threaded sleeve.
The tube is the original length so this might help someone workout what they`re off.(390mm from bottom of flange to top of tube)
Posted on: 2007/3/23 2:53
VIC DYNO HIRE
Not too shy to talk
Hey just wondering if a booster is needed and wat would be needed to fit them and how hard it would be?
thanks mate
Posted on: 2007/3/23 3:47
Hey Joshua1200,
A booster is not required. You will need a strut insert to suit and a spring platform welded at the right height for your application which i can do for whoeva wants them.
thats about it , and about 2 hours with the spanners!! I think the standard brake hoses will srcew straight in..
Posted on: 2007/3/23 5:51
VIC DYNO HIRE
From Geelong, Vic
they are 180b struts with early model commodore calipers, as in VK VL or VN executive ones
Posted on: 2007/3/23 19:13
