« 1 2 (3) 4 5 »
Re: WTB: Anyone have a "topgear" made h165 lsd they dont require???
From Bendigo, Victoria, Australia.
add Ronald to it aswell 1200rallycar. thanks
5-6 months suits me down to the ground
Posted on: 2007/4/18 7:23
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Coondle, WA Australia
hmmm sounds appealing....
are these goind to be available for the 1000 as well? or just the 1200?
For just under $1000 new diff, cut and shut to fit...
am now thinking......
what sort of deposit do you need topgear?
Posted on: 2007/4/18 12:19
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From South East QLD
I got 2 H190 LSD`s of top gear but havent got around to using them as of yet .. but the workmanship in the diff is AA1 + ..
Posted on: 2007/4/18 13:52
From California
yep! & feral errol confirms a++ work by topgear
i might be up for at least one. i'm still unsure if i even need one with a low hp motor, and if the car is not going to be drag raced. there seems to be some debate as to whether it helps you or hinders you in track or autox. more debate welcome ...
Posted on: 2007/4/18 14:19
no diff housing or cut and shutting ?? you're purchasing a torsen lsd centre designed to fit an H165 carrier, axels and gears ....
i've got one in my sedan (finally !!!) and aside from the quality of the workmanship its made the car even better to drive
Posted on: 2007/4/18 14:23
From Geelong, Vic
so youve tested to make sure both wheels spin then
Posted on: 2007/4/18 14:49
From Perth Western Australia
beattie wrote:
- HAHA! I just found out something very very very interesting about 165's and 1000s. Im exited!
Beattie,
What was it that you found out about the H165's and the 1000?? I'm interested as I happen to have one of these most desireable centers and also a 1000!!
If you happen to find two of those bluebird diffs I'll happily take one as well!
Posted on: 2007/4/19 7:29
Topgear, do you have any h190 ones left?
Posted on: 2007/4/19 7:34
I will take one as well.
Posted on: 2007/4/19 10:08
So let me get this straight.
Its just the diff centre. I will still need to go and find a H165 diff to have cut down.
I thought it was too good to be true. Here I am thinking that it is a complete diff, drum to drum with an LSD. for under $1000. still cheap, but not as good as I first thought... damn.... must keep dreaming.
Posted on: 2007/4/20 21:45
« 1 2 (3) 4 5 »
