Re: Commodore Diff Conversion
From Wanganui, New Zealand
I have on the floor a complete rear suspension from an MX5 Miata. I had a look at it for the Chickenhawk. It is quite a bit wider than a 1200 axle, 3 or 4 inches I think
I have already started this project. I've cut 100mm cut out of the centre which is really easy to do because it is a complete subframe. Regarding the problem with the upper arms, because it is going into a coupe it is not too much of a major to make the necessary mods for clearance. Being a rally car, rear suspension travel will be a priority...something that is a real problem with the standard rear suspension because of a lack of clearance between the diff legs and the chassis rails. This setup will cure that. The diffhead will also need to be changed...I need a ratio of around 4.8 to 5.1:1 LSD which at this stage it looks like being either Nissan or Toyota.
I'll keep you in touch with progress.
(Sorry about diverting from the original subject!)
Posted on: 2003/2/26 9:32
From Western Sydney
Sounds unreal mate, post any pics and info as you get them, very interesting...
Posted on: 2003/2/26 9:38
www.datnet.org
From Sydney, Australia
Which van? which year? which one? ...
I dunno which van. I work in the city (where there's plenty of them), and I'm keeping an eye out. I don't profess to be a guru at everything (unless I've had too many beers)..it was just an observation I made recently.
I'll keep looking for you.
Chris
Posted on: 2003/2/26 12:33
Cant wait dattodude!
Hey Dim do you have a spare porsche 944 rear end there next to the others you want to sell once you make up your mind on which one to use
Posted on: 2003/2/28 2:02
From Fort Worth, Texas, USA
Ooh, I just gave away my last 944 rear end yesterday! No, I'm just kidding. I don't have any Porsche stuff, that I know of.
Posted on: 2003/2/28 15:23
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From Western Sydney
I was talking to a guy that does alot of track work for GTP, club cars ect and he said the commodore diff with a fully adjustable 4 link would be the way to go.
Explained it well and probaby even gave me to confidence and info to have have a go my self.
Dattodude, might have to come and checkout yours when this come close to starting... yours will prob be on road by the anyhow.
I am thinking of commodore rear, so why not commodore struts? they bolt it, just cut them down, throw a threaded sleeve on, and you have commodore stud pattern all round with excellent brake and wheel options.
(The fact i get cost holden parts helps too)
Posted on: 2003/3/1 6:06
www.datnet.org
Man, I didn't know that... I would have gone for the Commodore fronts too, but I'd already done my front struts. With the Verada Gear.
The conversion for Datsun 4 stud, was quite hard. I'd stick with Commodore 5 stud, and use Commodore struts.
If I find an HSV Commodore with big Brembos I'll have to look at the commodore hubs and see if they can be converted to 4 stud.
You are welcome to come and look at the install any time.
Chris
Posted on: 2003/3/1 9:45
From Western Sydney
Commodore on all four would make things sweet, i had a vl strut bolted in except the spring hit, so thats no problems.
I have been told vx struts are the go, they run a similar bolt on hub style strut like fwd cars, much stonger and no flex.
I assume you got axles made up chris? I noticed that even making the diff have two short axels its still too wide by about 100mm. Is this right?
Thanks, I will make sure I check it out soon
Posted on: 2003/3/2 9:41
www.datnet.org
« 1 2 (3)
