CA20E?
From Vic Bendigo
Iv started a converstion for my 120y i wanted a cheap power up grade without turbo charging the a12 so i decided on a CA20E (multi point fuel injection) it was cheaper and i think will be more reliable than turbo charging the a12.
Any thoughts and coments would be greatly aprreciated
Posted on: 2007/4/28 20:33
Re: CA20E?
From Darwin NT
2 words best describe the ca20e those words are boat anchor
Posted on: 2007/4/28 22:33
current project 4x4 patrol...
Re: CA20E?
From Perth WA
i agree. A L20B would be a better engine!
those pintara motors are ####!
Posted on: 2007/4/28 22:55
Chris...
Re: CA20E?
From In front, and pulling away.Sometimes around Sydney....ish!
I run a suck through SU set up on an A14, good for 90 rwkw and an everyday driver. Plenty reliable if you respect it. And, much lighter than either an L series or CA20!
Posted on: 2007/4/28 22:58
Lifes good when your on BOOST!
Re: CA20E?
From Brisbane
Not worth running the ca20. A lot better engine choices and setups are out there. I once read a post from a member of this club. The best place for a ca20 is in the back of ute on the way to the dump.
Posted on: 2007/4/29 0:01
Re: CA20E?
From Adelaide. SA
Ca20's arn't that awfull but they do have flaws... The factory injections leave alot to be desired as do the heads cracking and warping... other than that, not a bad idea.
Posted on: 2007/4/29 1:16
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Re: CA20E?
From Toowoomba Q Australia
Nothing is going to be "cheap". It's probably cheaper to buy a whole new car with the conversion already done than to go through the whole engine conversion process yourself. I think there is a coupe for sale at the moment with a ca on this site. Very well priced too.
Either way best of luck
Posted on: 2007/4/29 1:42
Re: CA20E?
From Christchurch NZ
A guy locally has a CA20, with a CA18det head on it. It is a leathal weapon!
Posted on: 2007/4/29 1:45
Forced Induction!
Re: CA20E?
From Melbourne AUS
L series could be a better option
i believe you can use a 180b crossmember in the 120y to give you the L series mounts.
(i may be wrong though)
Posted on: 2007/4/29 4:31
1973 B110 A12
Re: CA20E?
From Vic Bendigo
Are they really that bad? is there anything positive about them because i already have the motor in it has got after market computer and injectors which are still waiting to be tuned.
Is there much involded changing the heads from a ca18? The conversion has been cheap iv only spent 80 dollars so far. I have got a bit left but hopefully it wont be to bad. As its my first car im not really after the power just something with a bit of stick not a xr8 killer thow it would be nice
Posted on: 2007/4/29 23:56
