(1) 2 3 4 ... 13 »
Bulk buy for turbo manifolds
From sydney
It would appear that there are 19 members of this site who are buying TnPs exhaust flanges, I am guessing this is because they want to get turbo manifolds made up.
Kegs paid liverpool exhaust $700 to make his up,and its a pretty good job.
Surely with the volume we are wanting we could approach a company that makes these sort of manifolds and get them to design and produce the manifolds at a greatly reduced rate, with us supplying the flanges.
I am thinking in the $300 range would be good, and at that price we would probably get even more takers.
I am going to do some research on this next week.
What do you guys think? Anyone interested?
Anyone got any contacts in the industry?
Posted on: 2007/5/11 14:43
Re: Bulk buy for turbo manifolds
From Perth
Make mine to suit T2 flange please
Definatly 1 maybe 2
Now which of those 2 is a better design ?
I like the 2nd for neatness and inlet manifold clearnace
But unsure of other clearances in the 1000 engine bay
Posted on: 2007/5/11 15:02
From Newscastle, Australia
yep I like the idea
with TNPshow manifold flanges it would be easy for a good welder to do this. the only things is that we would need to standardise the turbo type...or do the turbo of a particular brand have the same impeller and compressor mountings? ie with a T25 fit onto a T28 flange etc etc. I there are kits you can but that would be able to upgrade a turbo style that would be something to consider too.
Lets see if we can get a kit that would be able to turbo charge an A12 for under $1000.
That would give you a very basic setup which you could use to expand on later.
ie induction and exhaust manifolds (to bolt to a standardised turbo setup) and adapter for a suck through carb like an SU.
Would there be any takers???
The would be lots of turbo 120Ys etc on the streets in no time.
Posted on: 2007/5/11 15:36
Dont die wondering.....
From Brisvegas, oz
yeah i would be keen if it was about 300
has anyone else got any pics and designs
Posted on: 2007/5/11 15:53
www.camerasplus.com.au
From Freo
I like the second one,
again not sure on the clearance for the 1000..
the first has external gate.. I don't really need that..
Posted on: 2007/5/11 15:56
From south coast, nsw
i think this an excelent idea. a set up like this would work alot more effective then the the setup we are using on our race car now that uses a standard exhaust manifold and a j-pipe going under the engine mount (ex tyrie setup..) so i would be very interested in getting a couple.
Posted on: 2007/5/11 16:49
From Christchurch NZ
Something has occoured to me. If everyone starts turbing their Aseries, Then there will all of a suddden be a huge damand for forged pistons too. Then by economy of scale, they'll get cheaper too. Look how cheap chev stuff is.
Posted on: 2007/5/11 17:22
Forced Induction!
From Ipswich,QLD
Ok so a cheep reliable set up is what your after could someone drag a pic from my folder of the tubo set up i had for the 120y .this was very well made with a 1 piece flange and very light gauge pie which would be cheeper than steam pipe .the intake runners are 1 piece = less weld time better flow ,If your after a 1 piece flange ring shape cut in QLD and ask for a datsun 1400 turbo flange they have it on file , cheers
Posted on: 2007/5/11 17:28
From sydney
I hope these are the right pics.
Posted on: 2007/5/11 18:36
Light gauge pipe might be cheaper, but it will be more inclined to fail. If your making a manifold, a needs to be built to last.
Posted on: 2007/5/11 18:46
Forced Induction!
(1) 2 3 4 ... 13 »
