k20a b16a conversion
From ACT Aus
i was wondering if one of these series of engine will work in my 1200 ute
any help appreciated
jed
Posted on: 2007/5/16 4:46
Re: k20a b16a conversion
From Canberra
k20a was s2000 yeah? Would be sweet if you could get it in, they are a bretty big engine I think. Not sure if theres a rwd box for b16a
Posted on: 2007/5/16 4:49
From Adelaide, SA
Edit - sorry blonde moment...
Posted on: 2007/5/16 5:18
From The garage, NZ
the k20a is found in:
2001-2005 Honda Civic Type-R (EP3
2001-2006 Honda Integra Type-R (DC5)
2003-2006 Honda Accord Euro-R
and the k20a2:
2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP, European)
according to wiki anyway.
I have seen a few really sick s2000 (F20C) engine conversions, in such cars as the hatchi-roku (ae86). by all means they are amazing engines capable of producing awsome power but some people believe it to be blasfamy to do the conversion. if its power you're after and you have the money and time i say go for it.
Im unsure if there is a b16a rwd gearbox like tyrie said. Not a honda expert or enthusiast after all
Ask around on the honda forums and such if there is any rwd boxes, i dout it.
Posted on: 2007/5/16 5:21
From Newscastle, Australia
great engines but biggest problem is they are FWD and finding gearboxes to fit is the problem as well as access issues like distributors etc getting in the way. I think if you want to go Honda power (and Honda really do make great engines) then the S2000 is the go. Again i had issues with space with the SR20 so give yourself some time to do it ...it wont be easy at all...but quite possible. And the little 1200 will rip. Imagine 176 factory Kw in a N/A engine revving to 9000....in a lighteight great handling coupe. Awesome.
Posted on: 2007/5/16 5:28
Dont die wondering.....
From Geelong, Vic
but they cost an arm and a leg...maybe even a kidney too
Posted on: 2007/5/16 7:49
I once saw a vw beetle that had been modded to look like a baja style runner and in the back was a b16a1 motor. It was for sale. I wish I found out what transmission he used and or adapterplate he used to get that set up to work.
Posted on: 2007/5/16 8:06
From Tamworth, NSW
I got a k20a2 motor for $3000 thats the cheap bit i guessk series will require RWD gear box with a custom bell housing it will also need a cut an shut job on the intake manifold as it faces the wrong way. You will also have to re locate a/c etc.
As for b seres its mostly the same with a slight twist the motor rotates the opposite way to conventional engines
Posted on: 2007/5/16 8:48
Project coupe:
Just drive it
From California
Posted on: 2007/5/16 12:34
From Geelong, Vic
i heard it was in the 7k kinda range for engine gearbox and maybe loom from an s2000...damn newish cars
Posted on: 2007/5/16 12:41
