« 1 2 3 (4)
Re: How fast is your datsun?
From Wallyville (the Moon)
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
Posted on: 2007/5/17 6:35
From Newscastle, Australia
i reckon i hit 185 at Bathurst supersprint and also around same speed at eastern Creek. 63A box 5th gear 4.875 with a series at 7500rpm.
Can someone do the math.
Posted on: 2007/5/17 11:43
Dont die wondering.....
From Burbank, CA
153.6786 kph seems like a reasonable speed for the highway. Funny that when the car was built nobody went faster than 100 kph really and now if you go 100 don't even get on the highway.
The air resistance really gets fierce at 150kph, so without some aerodynamic help you really need a lot of power.
converted... is that with 13" wheels?... no it's the 4.8 diff... but it must be screaming fun...
Posted on: 2007/5/17 11:51
|||\ 81 KPB310 /|||
From Geelong, Vic
air resistance at 150kph you say....so its not just that my engine stops reving...its the winds fault
Posted on: 2007/5/17 11:58
From Burbank, CA
lol if you can try to roll the window down and stick your hand out...
better not you need both hands on the wheel at that speed...
if you have one of the add on airdams in the front it helps alot, but good luck finding one...
Posted on: 2007/5/17 12:01
|||\ 81 KPB310 /|||
From north brissy
mines easy i got a 180kph speed cut
Posted on: 2007/5/17 13:06
« 1 2 3 (4)
