Ok, so my clutch went out.
From Snohomish, WA USA
Actually I'm sure my clutch is fine but my clutch pedal has no pressure. I haven't had time to look underneath but the pedal mech. looks fine and there was fluid in the cylinder. I'm going to jack it up this afternoon and look underneath.
Any ideas?
Fixable without ordering new parts?
I gotta race this friday.
Thanks.
Posted on: 2007/5/21 20:55
Re: Ok, so my clutch went out.
From brisbane
Try bleeding the clutch fluid.
Regards Matty
Posted on: 2007/5/21 21:12
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Invercargill, New Zealand
Check the slave cylinder hasn't jammed.
Posted on: 2007/5/21 21:25
From Burbank, CA
quick question...
did it ever randomly feel soft prior to this?
I had a few clutch slaves go in a row, don't let not having a clutch stop you from driving ;)
it seems what happens sometimes, if the adjustments aren't done right, you can pop the slave out of the barrel and loose fluid, or burst a bad o ring and loose fluid.
adjustment is somewhat important, or the pedal feel will be off, and it'll tend to respond badly.
try to get it solved, i had to slam first gear a few times to get to a safe place... and now first gear isn't as happy as it should be... but that was like 10,000 miles ago now....
Posted on: 2007/5/21 22:35
|||\ 81 KPB310 /|||
From Huntington Beach, California
If that ever happens again, roll up to a light in neutral, then shut the car off. Put it in first gear, then turn the key and take off. Much better than slamming it into gear while it's running with no clutch. I've (unfortunately) been in that situation a few times over the years.
Posted on: 2007/5/22 1:27
From Burbank, CA
hmm that's an interesting idea... my starter will easily move the car, and i have a start button... clever. that's a good reason to have the gear reduction starter...
Posted on: 2007/5/22 2:58
|||\ 81 KPB310 /|||
Well, I got it fixed but it still may be a mystery. I found a second slave cylinder in my boxes of junk and replaced it. Bleeded it and it works great. Put the old one back in the box. If it happens again, I'll just do the same.
At least I fixed it in time for the drags tomorrow night!
Posted on: 2007/5/24 14:24
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
