Is it rare?
From Los Angeles,CA
I'd like to know if this steering wheel is rare or valuble? In other words, would I regret cutting it up to use as an adapter for a different wheel? Aside from being dirty, it's in excellent shape... http://datsun1200.com/modules/myalbum/photo.php?lid=13131
Posted on: 2007/6/8 9:10
Re: Is it rare?
From Townsville, Qld
I've got to say that I've never seen one of those wheels before. Also you should have a space between the image thing when you try posting them so it doesn't count the sentance as html or some crap.
Like this [img]http://datsun1200.com/modules/myalbum/photo.php?lid=13131[/img]
Dammit! it happened to me too?
Posted on: 2007/6/8 9:20
Re: Is it rare?
From sydney
Its not one ive seen in australia diffrent so do destroy what might not be able to replace
Posted on: 2007/6/8 11:02
Re: Is it rare?
Posted on: 2007/6/8 11:12
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: Is it rare?
Well, since nobody, including me, seems to have seen one before, then I guess it probably is rare.
Does the wheel bolt to a boss, or adapter, in the conventional way of aftermarket wheels? I'm guessing its aftermarket as I can't bring to mind any Datsun that used anything like it.
Posted on: 2007/6/8 12:20
Love your Datsun.
Treat it well.
Re: Is it rare?
From Coondle, WA Australia
Should we be concerned that you are doing 80 in the dark with no headlights and no revs (ie the engine off)?
I have seen similar style wheels on a cameria and corona. But never on a datsun. Not a bad looking wheel. Its kinda the industrial look. like Homer Simpsons chain wheel in the orange 2 door he had when he met Marge.
Posted on: 2007/6/8 13:14
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: Is it rare?
From California
if it's e10, then wombat might want it
Posted on: 2007/6/8 13:18
Re: Is it rare?
From Las Vegas USA
One of the 210's I parted had that exact wheel. For Rally driving I like the 2 spoke wheels, it should bolt right on.
Tom
Posted on: 2007/6/8 14:11
Re: Is it rare?
I dunno how it got to you, but it came out in the datsun 140Y in south africa. was originally ment for the rally scene, but instead was put into, lets call it ''the special edition'' 140Y. so dont cut it up, its has no $ value, but status for those models
the easiest way to go now is to get hold of a loose 1400 steering boss, and fit it. if you cant get that, then try a ISUZU 250kb pickup's boss (like the 98-99 model) the splines are the same, if you have such pickup that is. youll need to reem the inside a bit, and in front 4-6mm has to be removed then fit and adjust to desire. an hours work max(when your lazy)
Posted on: 2007/6/8 17:01
Re: Is it rare?
From Los Angeles,CA
It's definitely a factory Datsun wheel. It has a built in boss with a comutator on the back for the horn, and an itegrated Datsun logo horn push. If it had a thicker, smaller rim I'd consider using it as it's kinda cool... Guess I won't cut it up.
Posted on: 2007/6/8 17:34
