« 1 ... 9 10 11 (12) 13 »
Re: Bulk buy for turbo manifolds
From Burbank, CA
hmmm leaving the flange off is a very good idea...
I liked that GT1548 - T25 flange... anyone know why that would NOT be a good choice. this isn't a drag car, auto X, daily driver, long drives, TSD rallyes - so it needs to be able to be on the boost all day.
Specs:
Posted on: 2007/6/1 23:38
|||\ 81 KPB310 /|||
From adelaide
Dont forget that due to the welding process that warpage of the flange bolting to the head may occur, if it is warped even slighly chances are you will have trouble keeping manifold gaskets in the car. Mine was only slightly warped, a normal a4 piece of paper could just slide under one corner of no. 4 exhaust port when on a flat glass table. I went through about 5 gaskets, then got it milled flat and no problems now! I welded mine on the head too. I payed $50 to get it milled, im sure a bulk order would come in at nearly half that as you pay for them working out how to set it up to mill the right angle etc.
Posted on: 2007/6/2 4:37
1200 restoration project moving slower than it actually is
cough .... cough ........... are these getting any closer ??
Posted on: 2007/6/14 6:14
From Geelong, Vic
hey boof, make sure when you get yours that it comes over to my place for testing on one of my spare engines
Posted on: 2007/6/14 9:02
From Brisvegas, oz
hey boys im back from nz and the cars going in on tuesday for the first few sets to be made.
Posted on: 2007/6/17 6:27
www.camerasplus.com.au
From Perth WA
Just read this whole thread! 30 mins later...
Anyway i think im interested, as long as they clear a 1000. Well Neil is on the first list so i guess i can 'borrow' his to see if it all works. If it does im in!
So is a T2 and T25 flange or whatever the same? I just got offered a T25 cheap.
Posted on: 2007/6/18 14:43
Chris...
From sydney
Jake hope its all going well on the turbo manifold front, I am going to stick with my NA setup so you might want to cross me off your list.
Andy
Posted on: 2007/6/18 23:39
From Brisvegas, oz
yeah t2 and t25 have the same flange.
and no probs andy, i bet you might change your mind soon.
as for the progress my welding guy has built the frame for the manifold so he can make xact replicas of the oringinal and will be making 2 with flanges tommorow and 1 without, ill post pics of what they look like 2morrow
Posted on: 2007/6/19 7:46
Hey guys i,m in melb and can make turbo manifolds to suit any a series engine in any car if its possible to see the engine position etc if its a crazy conversion.
I also do full steel weld in cages too.
Am only part time at the min but trying to build up to a full time deal so anyone i can help please reply here or email
damo702002@yahoo.com.au
cheers DAMO
auto fab.
Posted on: 2007/6/19 9:08
From Gold Coast
How much would u be askin mate?? say ta fit a A15 oval port wit a T25 flange as an example?? to fit 1200 engine bay..
Posted on: 2007/6/19 9:50
