5speed reverse switch
Not too shy to talk
does anyone know if the four speed reverse switch is different to the 5 speed one?
im haveing trouble with the switch it doesn't contact the bar inside the gear box leaving the lights on the whole time.
Posted on: 2003/3/16 0:52
Re: 5speed reverse switch
From Sydney, Australia
I reckon they'd be the same. You'll have to pull them out and check, because I'm not one of the few who have a 5 speed. Although My stock 1200 has an auto.. so no need for a 5 speed.
Chris.
Posted on: 2003/3/16 10:59
From Brisbane Australia
To the best of my knowledge the switches are the same, one thig to check is that the wires are not shorting out under the boot
Posted on: 2003/3/16 12:13
From Melbourne, Australia
i dunno really but part that has the speedo cable thread on it is diffrent, cause i broke mine and cant replace!
actually i was stuffing round with the reverse lights at one stage and i think i did swap it over, i dont have any other 5-speeds sitting around so i musta got it off my 4-speed and the reverse lights work
by jinkies
i think they might be the same
Posted on: 2003/3/17 8:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sydney australia
if you're talking overdrive boxes,there are 2 different switches,due to the shift pattern.they don't interchange,but i think the a14 4 speed interchanges with the later 5 speed.the difference is in how the lights are turned on.one appears to connect the circuit when the plunger is plunged,the other breaks the circuit.nissan only list the reverse switch for the later one,i think.
Posted on: 2003/3/17 9:05
Then you need to get a normally-off or normally-on relay to fix it...not brain surgery.
Chris
Posted on: 2003/3/17 14:25
