« 1 2 3 (4) 5 6 »
Re: New Mad Dat Owners & Website
From Huntington Beach, California
The site looks very nice. I have a quick question on this part:
Product No - MD079
Datsun 1200 Ute Engine X-Member
Will this crossmember bolt into a 1200 coupe and provide a bolt-in swap for an A14? I've got some modified motor mounts, but the bolt-in crossmember is a much cleaner install, IMHO. Thanks!
Posted on: 2007/6/25 0:00
From Adelaide
Duncan, the X-member will bolt into the coupe, if you have the correct engine mounts the A14 will bolt straight up. This part is brand new genuine Nissan product, we were able to get them to re-make them for us.
Posted on: 2007/6/25 2:05
From Adelaide
Hey 120Fly. The guy that originally designed the site is Trent Turner. My partner Tam now maintains it and can do basic web and graphic design if you're looking for something that won't break the bank.
PM me if you'd like more info.
Posted on: 2007/6/25 2:12
From Perth
how about 4agze conversion kits for 1000's
Posted on: 2007/6/25 2:17
From SE Melbourne
by Duncan on 2007/6/25 10:00:38
Product No - MD079
I can confirm I used that ute crossmember to bolt up an A14 - I just used the engine brackets of a 120Y and the stock 1200 engine mounts.
Posted on: 2007/6/25 3:41
Mildman, Datsunless
Ah, thanks to you both. I remembered someone had done something similar, and I forgot that it was Mildman.
Posted on: 2007/6/25 3:58
From Flinders View, QLD
Someone mentioned SR20 conversion gear but you wont make is cause you say its illegial in most states, thats just for the turbo engine. I am putting it the NA motor and it IS legal by the power to weight calculator.
This may sound silly but dont the SR and CA power plants share similar engine and box mounts? The mounting kit I am buying for my SR20DE conversion (from Kev Rowley) is the exact same kit for the CA18. The main difference is the area around the top of the bellhousing (where the box meets the engine) in the tranny tunnel has to be beaten in a bit. Would that also mean your CA18 accelerator cable kit COULD work in my application, infact any of your CA18 stuff MIGHT work in a SR20 conversion. Anyhoo, you got some sweet gear for sale and I look forward to using some if it in the future. Keep up the great Fabrication work
Posted on: 2007/6/25 5:21
Just trying to put the bloody puzzel back together
From Adelaide
Bundy351, Thanks for the kind coments.
One of the reason that we dont make the sr conversion for the 1200 is that there has been very little demand for it as it is illegal in the turbo version, so the demand has been very low. It seems that most customers want turbo conversions.
I have never tested to see how similar the sr would be in the 1200 i may have to test this out. The gearboxes on the SR and CA are very similar as you mention, so if using one of our larger trans tunnels the top section might not be an issue.
As for accelerator cables, both engines throttle bodys are in about the same position, so it sould work.
Posted on: 2007/6/25 11:14
Maddat CA/1200 accel cable is a tight fit on SR/1200's because of the SR's throttlebody angle. It fits my SR with minimal room for movement but adjusts up perfectly. Photo looks like cable has plenty of slack, but its a fairly tight fit. My SR sits fairly close to the firewall.
Showing my 3 row pulley is a fair way back from the front rail of the car.
Crossmember show SR/1200 mounts very similar in position to Maddat CA/1200 mounts
Posted on: 2007/6/25 12:45
From Geelong, Vic
sssute, were you making the coilover top hats with inbuilt thrust bearing?
Posted on: 2007/6/25 15:45
« 1 2 3 (4) 5 6 »
