why do you need an internal and external fuel pump?
From Brisvegas, oz
yep as the title says or could you just use an external
Posted on: 2007/6/26 10:30
www.camerasplus.com.au
Re: why do you need an internal and external fuel pump?
From Townsville, Qld
???? what for, efi applications or something?
Posted on: 2007/6/26 10:34
From Brisvegas, oz
turboed a12 (small turbo)
Posted on: 2007/6/26 10:35
mabey one is supposed to assist with the fuel return to the tank
Posted on: 2007/6/26 10:38
From Ipswich,QLD
I used a carter fuel pump about the size of a matcbox car about 65$ from your local speed shop or autopro .they have enough flow to keep the fuel there when on boost but not enough pressure to blow the needle and seat open in the carby open .which is good way to go saved running a pressure reg .when my car came on boosts you could hear the fuel pump speed up and when you slowed down you can hear the pump slow down....
Posted on: 2007/6/26 10:55
From NSW, Australia
Well im not 100% sure about internal and external fuel pump i thought it was based on your fuel tank. As all EFI cars have one or the other. What im running is a lifter pump, like something that you would use on a webber engine. This fills up my surge tank, then a high pressure efi pump feeds the engine via a fuel pressure regulator. I am also running larger fuel line.
Im sure you all know what im talking about espically anyone with a surge tank.
Posted on: 2007/6/26 12:55
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
You don't need both, either for EFI or Carburetor. Sometimes people run two for:
- backup
- for racing with surge tank as described by BigD
Posted on: 2007/6/26 16:38
Some run a low pressure pump to provide VOLUME to the remotely located surge tank [when fitted] & a higher pressure pump that is located in the swirl pot/surge tank to supply the EFI system, while others simply run a single low or high pressure pump as the occasion demands.
Posted on: 2007/6/26 16:47
Love your Datsun.
Treat it well.
Not too shy to talk
From perth wa
was the car ever fitted with a surge tank?????
my a14 turbo fuel inj just runs a single VL fuel pump.
had to waste a good stubbie holder too trying to keep the thing quiet....
Posted on: 2007/6/30 15:03
