« 1 (2)
Re: Wiring headlights
From Sydney, Australia
I've got 2 in the boxes in the garage for my CA powered 1200 beast. Hella Part Number 1058 You need 2 of them!
Chris
Posted on: 2003/3/12 14:17
From Warwick, QLD
hey I've seen 90/100W bulb inserts for semisealed beams, how bright would these be?? Almost like have a permenent hi beam, how good is 80/100 are they better street driving lights
Cheers
Damo
Posted on: 2003/3/14 13:48
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Warwick, QLD
hey can anyone tell me what the markings on an alternator means, like B+ D+ D- etc, the alt i have got is a GM one, like the ones on the EA falcon. thanks
damo
Posted on: 2003/3/19 6:37
Team NEW SKOOL
From Canberra, Australia
I got 80/100 lights on my car.
I don't know how anyone can use the standard lights. they are so dim and so yellow.
I am not asure, but I think it cost me $170 for it to be done.
This was a few years ago now though...
I used to drive around all the time with high beams on when I had the standard lights. Noone flashed me ever. They couldn't tell that they were highbeams
Posted on: 2003/3/19 7:56
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Warwick, QLD
what about 90/100 lights, that would be like not having a low beam would it????
Posted on: 2003/3/19 8:49
Team NEW SKOOL
Not too shy to talk
It would b like driving lights all da time . blinding every one!!!!!!!!!!!
Posted on: 2003/3/19 11:52
From Warwick, QLD
ha ha ha ha ha ha yeah, I'm looking to get 80/100's
Posted on: 2003/3/19 12:07
Team NEW SKOOL
I'm pretty sure mine had 90/110s could have been 90/100s. If they are adjusted right, nobody cares. As the previous fella said, stock headlights are pretty bad, unless you are going for the "STOCK" look, and don't drive it much.
This is a "must-have" modification. Especially if you do a lot of night driving. Makes cruising at speed much much easier.
Chris
Posted on: 2003/3/19 12:36
From Brisbane Australia
I can't see there being much of a probem I have interchanged them with different models Honda's thru work.
The best upgrade I have found is to buy a Q4 headlight conversion kit and have a sparky wire it up with a relay an then you can safely run 90/130 bulbs without frying all your electrics.I had this done to one of my cars and with spotlights I was running 460 watts on high beam and it turned night into day !!
cheers Ade
Posted on: 2003/3/19 13:12
From Warwick, QLD
geez, ade, did ya lights start bush fires???
Now I know who started the big bush fires last year, it was you goin for a nightly cruise
cheers
damo
Posted on: 2003/3/19 14:43
Team NEW SKOOL
« 1 (2)
