Browsing this Thread:   4 Anonymous Users
At what boost?????
From lydenburg South africa
I would like to know, what is a safe boost for a standert alfa 1750 motor or all motors
Posted on: 2007/7/11 9:41
Re: At what boost?????
From Christchurch NZ
How long is a peice of string?
Posted on: 2007/7/11 9:50
Forced Induction!
From Mudgee NSW Australia
30psi should do it Nah seriously stock motor should be fine with around 8-9psi
Posted on: 2007/7/11 11:45
If In doubt run more BOOST
From South Africa, Bloemfontein
Another South African joins the club.
Welcome to the datsun neigbourhood.
First, tell us more about your car. Please don't tell us you stuck a Alfa motor in there.
Why did'nt you just go A12 or A14 with a turbo. There are some guys on this site that have gotten decent power with their A12, A14 or A15 turboed or supercharged engines.
Boost will depend on what internals your engine has and also what comp it is going to be running.
10:1 comp + turbo = big no no.
Posted on: 2007/7/11 12:08
1977 Datsun 1200GX
From brisbane
Difficult question as every motor is different but if the tune is good, i.e. correct fuel and timing, your engine will stand a better chance of coping with some boost. Fitting an intercooler will lower the intake temps and reduce the chance of detonation.
Matty
Posted on: 2007/7/11 12:53
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
I understood that most OEM (factory) turbos in the past were about 5 lbs of boost -- and with engine modifications. I'd be worried about more, you could certainly try it but monitor exhaust gas temp, air/fuel ratio and especially listen for detonation.
Posted on: 2007/7/11 22:14
From brisbane
I was just reading in the lastest Motor that the new Golf GT (not GTi) runs 2.5 bar of boost! Incredible.
Posted on: 2007/7/12 11:42
From SE Melbourne
Every 6 or 7psi roughly adds 1 to your compression ratio. Once you go over 11 or so it gets tricky not to detonate...so if your at a 10 CR is so then much over 7psi could be trouble.
Posted on: 2007/7/12 13:59
Mildman, Datsunless
Yes the new car engines are putting out incredible power, even the naturally aspirated ones. As much as I can figure, the biggest factor is variable valve timing, even in economy models.
Posted on: 2007/7/12 17:48
My ride is a 1200 deluxe.I trade a mini body for a 1750 alfa motor and a 2.0 nissan diff,so I could not resist the temptation.I would not recommend this conversion to anyone.I am halfway there but had tons of problems alonge the way.But it`s a lot of fun.
Posted on: 2007/7/14 18:58
