Steering Column
From Brisbane
i have a leak coming out of steeering column..... how hard is it to fix? and are seals easliy availalbe??
Posted on: 2003/3/24 13:45
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: Steering Column
From Canberra, Australia
When you say coming out of the steering column, where do you mean?
Posted on: 2003/3/24 14:16
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Steering Column
From Brisbane
out the bottom i am pretty sure it is hard to see but is there seal there?? there is seal where the column goes in ? might be there...
(p.s i just realised that i put this in the classsified section, S%# t )
Posted on: 2003/3/24 14:27
Re: Steering Column
Mine had kinda the same thing.
It was actually brake fluid dripping onto the column and then dribbling down till it got to the floor.
Might wanna make sure it's not this first.
Posted on: 2003/3/24 15:44
Re: Steering Column
From Brisbane
what does the column box contain oil or fluid?? cause the leak is oil....
Posted on: 2003/3/24 16:02
Re: Steering Column
The column doesn't contain coolant or oil ... however the steering wheel bearing (just behind the steering wheel) can leak a little lubricant. Mine did this.
You have two choices:
1. Do nothing, it won't leak much
2. replace or repack the bearing
Posted on: 2003/3/24 16:19
Re: Steering Column
From Fort Worth, Texas, USA
DD, I think he means the other end of the column. Down by the steering box.
Posted on: 2003/3/24 16:32
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
Re: Steering Column
From Brisbane
yeah the steering box
Posted on: 2003/3/25 1:27
Re: Steering Column
First you said the column, now you say the steering box ... which one is it? Or does your 1200 have the old solid steering column firmly attached to the steering gear? There's not supposed to be any fluid in either type of column ... My confusion is I've never seen the old style. I think they were not used in US 1200s.
In either case there should be a rubber seal where the column or the shaft passes through the firewall, the rubber covers the hole in the firewall. Is there fluid above this either inside the vehicle or under the hood? You'll want to look up there with a flashlight and see.
Posted on: 2003/3/25 6:34
Re: Steering Column
From Brisbane Australia
Just putting in my 2 bob's worth, your steering box contains oil normally the same grade as your g/box, this will flow up the column to some degree it will have a seal where the steering arm comes out of the box it should be a std size so most steering specialists should be able to replace it but it would mean removing the entire column.
not a fun job
cheers Ade
Posted on: 2003/3/25 13:16
