ford kidny beans on datsun ute
hi guys I have a cut down hilux diff (lsd ) can i fit ford rims
Posted on: 2007/7/22 9:36
go hard , go quick , see yaaaa
Re: ford kidny beans on datsun ute
bloody hell come on guys even just some info
Posted on: 2007/7/22 10:43
Iam not putting sh@t on the forms
Posted on: 2007/7/22 10:45
From Adelaide, SA
Geezus dude you replied to your own thread twice in an hour and a bit - yes you are!
Be patient for fuxake!
Posted on: 2007/7/22 10:52
From Coondle, WA Australia
probally best to call your local tyre fitter. They will know straight off the cuff.
But at a guess
No.
Jap 5 stud are different from Ford 5 stud i think. You then have to check all the other tyre stuff like the total width, off set etc...
best to ring your local tyre place.
Posted on: 2007/7/22 10:59
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Geelong, Vic
measure the PCD of the axle studs, if its 114.3mm then yes other rims that are 114.3 PCD will fit eg nissan and ford 5 stud
i see a lot of lowered hi aces with ford au xr8 rims onthem, must be same stud pattern. nissan r33 sklyines can use ford au-ba steelrims ive seen, especially for burnouts and drags.
Posted on: 2007/7/22 11:05
From Townsville, Qld
yep right on the money, and why stop at drag rims for ba steelies? if i had a Skyline I'd use them as stockers with a set of supercheap wheel covers, the really tacky chrome kind
Posted on: 2007/7/22 11:34
From Brisbane Australia
yes ford rims are the same stud patten as hilux
Posted on: 2007/7/22 19:57
thanks mate! I going to run the 14x8"s on the back. how about s15 to kb ford rims
Posted on: 2007/7/24 11:54
