diff & brakes upgrade for my 1200 ute
Quite a regular
From TOWNSVILLE QLD
hey all just looking for some advice on a stronger diff and some brakes for my 1200 ute ,i want them strong enough for eather a sr20de or a ca18det. my target is 120 rwkw also some advies on sr20de and what u have to do to them to get 120rwkw as im still not sure what path im gonna go down maby this will help me out.
any advice will be great
thanks
Posted on: 2007/7/23 21:00
Re: diff & brakes upgrade for my 1200 ute
From perth airport
from memory sr20de 100kw and ca18det 140kw
im shore wit a good exorst and pod filter the sr20de should be close to the 120kw your after
Posted on: 2007/7/23 22:01
From Flinders View, QLD
Chech the Tech section dude, there is plenty of info there.
A shortened R31 skyline diff is the go dude, well thats what most people up-grade to when the power becomes too much for the H165. Some choose Hiluxs diffs and others even go the ALMIGHTY ford 9in. There is plenty of bits available for the R31 diff as it is just a Borg Warner diff with 4 stud axles. So you could whack in a crappadoor or falcon LSD and there are a few ratios to choose from.
I see you are in townsville, a mate of mine at Stainless Customs is currently doing this exact conversion, once he finishes I can find out some details and let you know how it went. As for the brakes the R31 diff comes with disc brakes so all you will have to do is hook up the hydraulic lines and modify a handbrake set-up.
Engine wise is a personal thing. For my conversion (ONE DAY) I am going to put in the SR20DE cause I reccon there is allot more aftermarket parts at better priced compared to the CA18DET. Most people go the CA18DET cause its powerfull right from the word go, its also a bit lighter and some say its stronger. Just decide waht you want out of the engine and go from there.
Posted on: 2007/7/23 22:05
Just trying to put the bloody puzzel back together
Quite a regular
From TOWNSVILLE QLD
thanks man i know some one that works there. his name is dylan gibbs so ill go in with him some time in the next coupple of months first i need to buy a half cut of a s13. also i was woundering if the brakes from the s13 will fit on the stock front axel
thanks for all the info
Posted on: 2007/7/24 8:30
From Geelong, Vic
if your ute has discs standard then the s13 brakes can be adapted on, search silvia brakes or something like that on this site and you should find plenty of info
Posted on: 2007/7/24 8:42
s15 in the front , and hilux lsd in the back mate hey bundy351 ther is chris can aprove the sr20 det in townsville in 1200 ute's sr20 de are pusssssssed
Posted on: 2007/7/24 12:31
go hard , go quick , see yaaaa
From perth airport
hey syco didnt you find out that your ute cant be aproved wit a sr20det ??????
reminds me of a good movie 'wat do ya know syco ' not much lol
Posted on: 2007/7/24 19:45
Hay sycodat, who are the people who approve SR20DET into 1200 utes??? I would like to know what I have to do to make it legal cause according to the department of transport only a 2.0l NA motor will legally fit. 1.8L is the largest Turbo donk
Posted on: 2007/7/24 20:28
Quite a regular
From TOWNSVILLE QLD
are u 100% sure about sr20det in 1200's in townsville that would be great,
Posted on: 2007/7/24 20:44
From Geelong, Vic
not to question sycodats credablity or anything
but does he actually have a car?
apart for the ute that runs a 9.1 with the hybrid 20bsr20det monster
some pics or something would be good
Posted on: 2007/7/24 22:05
