« 1 (2)
Re: Stupid question who can help
It is required unless you have an ignition coil with a built in ballast resistor such as a Bosch GT40.
Dont you mean the GT40-R?
(I recently got these 2 mixed up)
Posted on: 2007/8/1 3:27
oh wait is it the other way around the r stands for use with a resistor? Quote:
Posted on: 2007/8/1 5:02
From Adelaide, SA
Correct - GT40R must use an external resistor.
Ballast restistor reduces the voltage running through the points to stop them burning out.
Actually, the ballast resistor limits the CURRENT flowing through the COIL to stop it burning out.
Get an ignition coil with a built in ballast resistor and get rid of the ugly one. Easy!
Posted on: 2007/8/1 5:16
From bathurst nsw
from my understanding bigd
electronic dissy= "poof" ballast resistor gone
because it doesnt have points anymore
Posted on: 2007/8/1 5:20
My car gets me from A to B...Just faster ;)
From Perth WA
goto your parts shop and ask for a ignition coil to suit a non balast resist car. Wire it up as the old one is but join the 2 wires together that would normaly go into the balast resister.
Posted on: 2007/8/1 5:28
Chris...
From Bendigo, Victoria, Australia.
and also to ensure that only 6V enters the +ve terminal of a 6V coil.
hence why removal of it is required for a installing a 12V coil (as a 12V coil won't work well on 6V)
it is simply a piece of nichrome wire behind the ceramic covering. nichrome has a high resistivity (for a metal).
heat soak wouldnt be an issue as the nichrome wire uses the 6V it drops across it to heat the wire up. plus it is in the engine bay where the temperature is never really cold...
Posted on: 2007/8/1 5:29
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From NSW, Australia
Boys you've done it again. cheers thanks for the info, not only will this mean less old parts that can break down but help tidy up my engine bay
Posted on: 2007/8/1 19:17
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Make sure the ignition controller can handle the extra current. The Ballast Resistor limits current flow -- not just to the coil but through the switch too (points or electronic unit).
Posted on: 2007/8/2 16:47
While were asking stupid questions....what would happen if you ran a GT40 through the ballast resistor? No difference....or.....?
Posted on: 2007/8/4 16:09
From Burbank, CA
loose the points dizzy! then you won't have to fool with anything in the dizzy ever again. You'll probably gain a bit of performance too...
Posted on: 2007/8/4 17:02
|||\ 81 KPB310 /|||
« 1 (2)
