HELP!! ANYONE KNOW HOW TO REMOVE/REPLACE CORRODED WATER COOLING PIPES ON ENGINE BLOCK??
Quite a regular
From Perth, West Australia
HEY ALL, ANY HELP IN REGARD TO WATER COOLING PIPES REMOVAL/REPLACEMENT WOULD BE OF GREAT HELP. HAVE DONE A SEARCH BUT CAME UP WITH NOTHING!
Posted on: 2007/8/3 1:45
Re: HELP!! ANYONE KNOW HOW TO REMOVE/REPLACE CORRODED WATER COOLING PIPES ON ENGINE B
From Canberra
pretty sure its just an interference fit, so pull and twist...
Posted on: 2007/8/3 1:47
From Geelong, Vic
vice grips and a hammer
Posted on: 2007/8/3 1:50
From Adelaide, South Australia
Nah you have to weld on a T shape pipe then smack it off with a hammer.
Have fun.
Posted on: 2007/8/3 2:09
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Quite a regular
Cheers guys for quick reply. Would have replied sooner but i could not get back into the site for some reason. From the sounds of things its a no brainer to get it off, thought it would have been more difficult.....maybe it will if it doesn't want to get off! Are the replacement front and rear pipes readily available from most auto shops?? And one other thing, would it be worth changing the welsh plugs while im at it to brass ones? Anyone have the correct sizes for welsh plugs and pipes to use?
Posted on: 2007/8/3 4:41
From South Africa, Bloemfontein
Get some of that penetrating oil that you get in a spraycan.Spray alot of it so that it can penetrate good into the rust and crap.
Weld an extra peice on the pipe and good luck.
Those penetrating spray have done some miracles for me with regard to this problem.
Oh, replace the welch plugs while the engine is out.Better safe than sorry.
Posted on: 2007/8/3 5:18
1977 Datsun 1200GX
From Melbourne, Australia
good to see you figured out how to turn caps lock off
Posted on: 2007/8/3 5:20
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Quite a regular
thanks for that advice 1200GXman. Have you found some more of those Datsun alloy valve covers? Any idea of cost for one and postage cost to west aust?
Posted on: 2007/8/3 5:24
If you are quick on the draw, come in contact with boofhead.
Posted on: 2007/8/3 5:28
1977 Datsun 1200GX
Quite a regular
Guess i can figure out some things for myself 1200rallycar
Posted on: 2007/8/3 5:29
