« 1 (2) 3 »
Re: L18 into 120y info
From Wagga Wagga, NSW
go the l series the torque will blow your mind!
it is well worth the effort
Posted on: 2007/8/28 10:56
From Geelong, Vic
geez $340, thats more than it cost me to convert to an L series
Posted on: 2007/8/28 10:59
From Adelaide, Australia
Dont most people use the 180b stuff because it pretty much all bolts in?
Posted on: 2007/8/28 11:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Townsville, Qld
180 engine crossmember is what I've always heard, has anyone ever compared one to a 200B crossmember? or is it just the same part backwards or something
Posted on: 2007/8/28 11:07
From Geelong, Vic
200b and 180b stuff is very different
ive got 180b stuff in my 120y....yet to whack an engine in it
but yes it all bolted right in after cutting the castor rod mount thing down
Posted on: 2007/8/28 11:11
From Portugal
I have a question...what about stuff from a 510? In Portugal we have a lot of L16 SSS, and i've been considering this swap...is the the cross member from a 510 useable on a 120Y? what is the diference between the 180B crossmember and the 510 one? Overhere i dont see many 180B...and that could be a problem...hehe...peace guys...
Posted on: 2007/8/28 13:53
Datsun 310GX(FWD) and 120Y(RWD)...drive straight or drive sideways...
From Perth W.A
yeh after notching the castor rod mount it bolts in, and then the engine drops in.
i ended up cutting some of the rad support mount and rolled the edges, i used the stock 180B rad as well and can still use the stock fan.
i'm very happy with the result so far. just need to hook the front brake line up and bleed them and i can give it a maiden voyage
good luck with it, and don't hesitate to ask questions.
just try and get a Stanza 5speed or an R30 5 speed as they bolt up with a 120Y auto tailshaft.
Posted on: 2007/8/28 14:57
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
how about L16? is it fit directly?
Posted on: 2007/8/28 18:28
From Geelong, Vic
L16 will fit just as easily as an L18 if you use the L18 sump
Posted on: 2007/8/29 1:29
From Portugal
What about the cross member from the 510...what parts can we recycle on to the 120y? like brakes and struTS? is anything bolt on? thanks...peace...
Posted on: 2007/8/29 1:32
« 1 (2) 3 »
