« 1 (2)
Re: 3000-7000 rpm
Thank you guys I will get a quote from all mentioned and let you know how it works out.
Harry do you know if the L13 block is the same as the L16?
Posted on: 2003/4/9 12:38
Re: 3000-7000 rpm
From Brisbane, Australia
I believe so. I think it's just the stroke that's different. But they're like rocking horse sh*t here. I've only ever seen one - in this2 door 510 with L18 internals.
Posted on: 2003/4/10 1:17
Re: 3000-7000 rpm
From Christchurch New Zealand
i have the kelfords F29 gring cost about $160+gst if you supply the cam or $265 if they youse one of thier cams they are a mean cam
Posted on: 2003/4/10 10:45
"If your not living on the edge your taking up too much space" Rod Millen
Re: 3000-7000 rpm
I thought maybe it would be a shorter block but it sounds like the L16 is an L13 overbore and the L18 just change of crank? is that right?
With the Kelford cam... Ill have to post a cam over. Or better I can get a new billet with hollow centre for about 370. Thats not too bad for new technology (hollow) unless others do it too.
Posted on: 2003/4/10 14:05
Re: 3000-7000 rpm
not too sure about the bore stroke specs of the L13 - never looked them up. Have you found one??
Posted on: 2003/4/11 6:19
Re: 3000-7000 rpm
Quite a regular
From melbourne
datrally in melb will do cams find the best one to suit your motor as well not sure of prices but they are probably the best in melb for datsuns
Posted on: 2003/4/11 7:16
Re: 3000-7000 rpm
No but I thought if it is the same as the l16 block. I could use the l16 block in an original 1600 I found at the wreckers.
Datrally send the cams away and charge a premium unlike cam joints who do everything in house. Datrally is great but their costs are beyond the average jo blo.
Posted on: 2003/4/11 12:13
Re: 3000-7000 rpm
From Melbourne, Australia
D, you need to talk to my elec dizzy guy (who i still havent contacted again)
he was telling me all bout cams and stuff and knows guys who do that stuff, he was really keen to help out if i needed it too
mind you he builds motors for sprint cars not road cars so you can only use so many of his ideas before you have a motor which is undrivable on the road
Posted on: 2003/4/11 12:19
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 3000-7000 rpm
1200rc, sounds like a sprint car engine wouldnt be the good for my 2 points left on my liscense but a car maxing out at 7200 would be just the call.
Posted on: 2003/4/11 12:52
Re: 3000-7000 rpm
mate YOU are not good for the 2 points left on your license
Posted on: 2003/4/11 13:00
1200 Coupe Rallycar
« 1 (2)
