Browsing this Thread:   5 Anonymous Users
Converting 4 door 1200 sedan to 2 door (photochop pics)
From Sydney
Hi all, has anyone converted a 4 door 1200 to 2 door?
I know some of the 1600 guys have done it but it looks a bit wonky, i did a quick photoshop on these two 1200 sedans and it looks pretty good?
Ultimately i would like to weld up the rear doors on a sedan and add the coupe flares (it's a race car).
It almost looks like the original 2 door sedan, just not as curvy, but still well proportioned.
Posted on: 2007/9/17 11:23
Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
From Melbourne, Australia
"go_the_datto" did it, check out his pictures and link
Posted on: 2007/9/17 11:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide, SA
You're right the 510's converted look a bit odd but the 1200 looks great like that!
If you're doing a racecar then remove the 2 piece windows and replace them with 1 piece perspex
Posted on: 2007/9/17 12:52
From Perth WA
What about moving the B pillar back and using like Coupe doors(assuming they are longer like a thou)?
Posted on: 2007/9/17 13:32
Chris...
From Geelong, Vic
that would actually make it very very close to the real thing seems as the 2 doors use coupeish doors(with different tops)
Posted on: 2007/9/17 13:46
From sydney
The 1200 post is shorter than a 1200 sedan this you must consider when building your toy
Posted on: 2007/9/18 10:43
2dr sedan door skins are diffrent to coupe skins
Posted on: 2007/9/19 12:24
1200 Coupe Rallycar
From Perth Western Australia
not quite that simple... as mentioned before, the tops of the doors are different, which means you would have to extend some standard 1200 door tops, and put them onto coupe doors... Then you'd find the glass will be different, and neither coupe glass or standard sedan glass will fit, and probably not even standard 1200 2 door sedan glass.... You'd have to get custom... I s'pose its not that bad since glass in 1200's is straight!
Don't let me put you off though, go for it
Posted on: 2007/9/19 13:04
From The garage, NZ
2dr is a lil more roundey in the rear window too
Posted on: 2007/9/19 20:52
Sure, everything has been done before:
Tudor 1200s
Posted on: 2007/9/20 0:25
