« 1 2 (3)
Re: perfect fit in the 1000 coupe
From Adelaide, SA
Looking schweet!
Ya know, I have an SC14 supercharger - all ya need is the CRS Kit to fit it
Posted on: 2007/10/9 0:10
From gold coast QLD.
This should be an interesting Sports Sedan mate,have you thought out the front suspension yet?
Posted on: 2007/10/9 4:09
From Adelaide. SA
Heres what I did tonight. Trans tunnel has been sufficiently made bigger and the trans mount is half done. i'm trying to get as much done before I go to Darwin next week
--BERT, i havent thought of what to do with the suspension yet. was going to leave that till last. I have got brakes sussed though. Silvia front rotors should be enough!!
Posted on: 2007/10/9 11:42
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Sydney, Australia
V6 KB10... you know you want one!
+ cruise control...thank you very much
Posted on: 2007/10/9 11:49
From Adelaide. SA
Well this weekends dedicated to the 1000! Last night I did a bit of work on the trans tunnel and spent a few "minutes" removing the sound deadening from the floor, getting it ready to seam weld.
Posted on: 2007/11/2 21:53
Peter Brock
From Sydney Australia
thats a fun job hey! i just finished it on my kb10.
you should have a look at some japanese websites about the suspension, they put little coilovers in there. I have also heard of people resetting and adding leaves to the standard reverse leaf front. Someone even welded strut towers in!
Cheers
Posted on: 2007/11/2 22:41
From adelaide
how do you go with clearance between xmember and bonnet. I am over half way through vp v6 and t5 into tg gemini and the sump is only 5mm from xmember with maybe another 5 if your lucky between bonnet and alternator. Lucky its solid mounted so shouldnt hit. Will go hard in a 1000
Posted on: 2007/11/4 3:58
1200 restoration project moving slower than it actually is
From Geelong, Vic
there is plenty of sump on these motors to shave down to get the engine lower
Posted on: 2007/11/4 4:34
« 1 2 (3)
