« 1 (2)
Re: No Boost! Dead turbo......?
From Melbourne Vic
i'd be very surprised if the wastegate was jammed open, they have a heap of tension on them. i have tried blowing into a boost guage and i think my max was about 3 psi so blowing into the actuator probably won't tell you much
Posted on: 2007/11/1 12:13
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Cape Town ZA
I think you should check the waste gate, the actual gate might have worked itself loose from the shaft that is connected to the actuator. That may explain the buzzing, because it's possible that it is now flapping around like hell when you give it stick. Also, the actuator might not be stuck open, but the spring might be screwed, so that it doesn't keep the gate closed if it even reads a tiny bit of boost, so it will open immediately.
Posted on: 2007/11/1 19:03
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Re: No Boost! Dead turbo......? And the winner is.......
From Bris-Vegas
And the winner is.........
Those who thought the wastegate was jammed open were the closest to the mark.
Luckily - It was just that the circlip that holds the linkage from the actuator to the wastegate on had come undone & the wastegate was flapping in the wind.
Cheapest turbo repair I've ever made.....: - )
I know what do next time I book it in for work & the guys in the shop get that "I'm going to take your pride & joy & thrash it" look.
Un-hookie the old linkage.
I've fixed it, but the buzzing's still there..... Only happens at 2000rpm!
Any thoughts what this could be?
Posted on: 2007/11/2 3:39
CA18DET '74 1200 ute project
From gold coast queensland
did you use a new circlip?
Posted on: 2007/11/3 0:29
From South Africa
Damn I had exactly that happen to me... and you will not guess where.... of all places, it happened to me while staging up against some turbo'd Charade at a local drag meet... man that sucked.... this POS 3cylinder crapped all over me....
worst of it all, I fixed it, in time for the next round, so my car was going good again.... this just made every one think this Charade really was that fast....
Posted on: 2007/11/3 18:57
« 1 (2)
