arfetermarket fuel pump on a series?
From QLD
hello peoples,, the fuel pump on my a10 seems to be broken its not wanting to pump any fuel ,, just wondering if it would be worth putting an electric pump on insted of fixing the old mechanical one,, if so ,what kind of fuel pump do i need ?
are there different ones ? which is the best ?
Posted on: 2007/11/14 8:33
Re: arfetermarket fuel pump on a series?
From Warburton vic
go for the standard one they work well
Posted on: 2007/11/14 8:39
From Christchurch NZ
Just a cheap electric one from repco should do the trick.
Forced Induction!
From QLD
i have heared a phew people say to go the manual one but also electronic one ,, i am really going for the cheapest one though because im selling the car,but i dont yet know which one is cheaper.
Posted on: 2007/11/14 8:46
From Warburton vic
well go to a wreckers & get a second hand one or im sure some one on this sight might beable to help you Thats probably your cheapest option
Posted on: 2007/11/14 8:51
From Perth WA
A10 fuel pump repair kits pop up pretty often brand new on ebay. If not im sure you can buy a kit from a auto shop. The cheapest elecy pump i could find was a $66 facet.
Posted on: 2007/11/14 9:27
Chris...
From QLD
when bying a fuel pump, do i look for a certain size or pressure not really shure never bought one before?
Posted on: 2007/11/14 10:02
From perth airport
datsuns a10s arnt gonna need much fule i would say any electric fule pump for a car would be fine
Posted on: 2007/11/14 11:15
perth airport parking
Datsun 1200 ute A14
From Newscastle, Australia
yeah any electric pump...but you need to take the old one out of line as well as taking it off the engine. I have heard that the mechanical pump just sitting there may overheat due to no fuel/liquid running through it to cool it. You will need to make a blanking plate. Tou will also need to run a regulator in between the carb and the new electric pump and set it to 1.5 to 2 psi. 4 psi is a little too much pressure for the carb.
Posted on: 2007/11/14 19:55
Dont die wondering.....
From QLD
cheers guys thanks for you help! Quote:
Posted on: 2007/11/14 21:07
