« 1 (2) 3 »
Re: The exhaust fumes smell weird
From portugal
Hi mates! ok, it like this... the car runs ok, some times i smell petrol in the car, but it
Posted on: 2007/12/7 0:06
From Coondle, WA Australia
Its the two stroke oily smell right?
yeah beattie, Ill go with you. perhaps a rear main oil leak onto the exhaust??
or perhaps your are buring a heap of oil past the rings?
If the motor is rebuilt, how long ago? Sometimes new rebuilt motors will burn a little oil till they bed in.
Posted on: 2007/12/7 0:19
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From portugal
yea... you might be rwight, the engine was rebuilt all new abaut 9 mothes agou but it just had run 1500 klm. but the oil level is ok. and it
Posted on: 2007/12/7 0:36
From Cape Town ZA
Sometimes when I drive my car, I get a rotten smell that makes your eye's shoot full of tears, but that's usually when I had a bowl of beans the previous night...
No seriously, you say you've rebuilt the engine, and it's only run 1500km, it might be that there is still a lot of oil left inside the exhaust system from when the engine was in a bad state. It's gone and gathered in the cans and pipes, so it will probably take some time for all of that to burn away. Taking it on a long trip, and giving it a couple of long extended runs at full throttle might heat the zorst up enough to get it burned clean quicker.
When you park the car, the fumes aren't being blown out of the zorst, and that oil get time to cook in the hot system, so it will expel lots of pungent oil fumes when parked in the garage. That will explain the "old-oil-in-clothes" smell...
Posted on: 2007/12/7 6:47
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From South Africa
I ask a buddy of mine about this. He said you should advance your timing to get the moter to backfire through the exhaust to burn it clear. (Just a thought)
My UTE also had a bad smell when the rear crank seal started leaking, it was a result of oil dripping on the branch manifold.
Posted on: 2007/12/7 8:05
___________________________________
2006 Ford Bantam
2004 Ford Ikon
From South Africa
This happens to me alot.
Posted on: 2007/12/7 8:06
2006 Ford Bantam
2004 Ford Ikon
From portugal
hi mates! thank
Posted on: 2007/12/7 23:43
pertrol and diesel mix would do that... ahh well you know for next time!
Glad its nothing major
Posted on: 2007/12/7 23:55
From portugal
heap!
Posted on: 2007/12/8 0:29
From Seattle ,WA.
just don't do the diesel in a gas engine - very bad!
Back in the day when gas nozzles were all the same size (at least in the US) you could mix them up easily.
I had to drain a few customers tanks of diesel when they came into the shop.
Evan
Posted on: 2007/12/12 1:31
« 1 (2) 3 »
