Need help:- A12A swap to A12 in 310 Sunny
From Newscastle, Australia
Hey guys I have a B310 Sunny in Aus and we are using it for khanacross which is a rally/time trial event on dirt. We just bought a fresh A12 to replace the A12A it cam with. The engine mounts do not line up...the A12A originally in the car had engine mounts in a similar position as the A15. The fresh A12 that we are putting in has the engine mounts set further forward to the front of the engine. Is there and adapter kit that can help with this or do I just make brackets to suit???
Posted on: 2003/5/4 3:10
Re: Need help:- A12A swap to A12 in 310 Sunny
From Auckland, New Zealand
The A12 you have is one of the early ones. the quickest & easiest way to mount it is to try and get the original engine mounts that bolt to the block the it all should bolt up.
You will also notice the engine engine has the distrbutor further forward that the last one i.e. the A12 with have it under the #1 plus, where as the A12A will have in under #3.
What are you doing with the A12A block?, I'm trying to find one so I can re-build my engine.
Posted on: 2003/5/4 4:48
Hi Brent thanks for your quick reply...yeah we tried using the original mounts off the older style A12 using the original strong sunny box, but we were 50mm out...the mounts on the engine being 50mm forward of the cross member. The mounts on the engine were also too high, lowering the engine made the sump hit the x-member. We have made up some right angle plates to compensate for this but appears like a weak point if we go racing.
Also you can have the A12A block for free...the engine would only run on 3 cylinders and was blowing alot of smoke when we picked up the car. Just let me know how we can get it to you. Also Teretonga was investigating getting some of his race parts he has in storage in Invarcargill. Would you have some info of importing them here to AUS??? PM me for my phone no if needed.
Posted on: 2003/5/4 5:06
Hey Converted.
I was wondering if i could scab the Head assembly off you? seeing as the other dude only wants the block? Ill pay all postage fees ofcourse. I recently got a a12 block off 1200rallycar and i need the bits to complete it. im in melbourne. thx
Posted on: 2003/5/4 5:28
Love to give it to you but Brent wants the whole lot too...so first stab goes to him. I mentioned the block to him in a PM as I thought it would cost heaps to ship to NZ, but if he pays for that then I'm happy to send it to him. Otherwise you can have the head.
Posted on: 2003/5/4 12:08
This is probably not the A12A engine. The A12A has different size pistons and CC and was used in the USA B310 (210).
Cars from 1974 are using the "new" A12 with the mounts and distributor moved. See discussions:
A12-SA Engine (from a sunny) (has information on motor mounts)
A12-A15
Posted on: 2003/5/4 18:46
Thanks DD but reading that thread doesnt help me much...as I am trying to put the older style motor in a later typ car. Obviously not often done...this was only considered due to the enginebeing made available for a great price.
I will make up some brackets...and in the future stick with the 1200 as a platform.
Posted on: 2003/5/5 12:03
From Melbourne, Australia
new motor to older car
surely its just the same as this then, these are the blocks you need to make, in reverse
Posted on: 2003/5/5 12:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Invercargill, New Zealand
Nah - the motor is too high and too far forward for a plate to work.
Posted on: 2003/5/5 14:06
By the way Rallycar...how do you get that photo thingy in your thread ID....I can only get a stupid little kangaroo...youve got twin webers!!
Posted on: 2003/5/6 0:46
