running efi engine with standard carbi fuel tank and surge tank
noticed a bit of air pressure when taking off cap after running for 5 minutes
im running efi engine standard tank with a surge tank setup
with a brand new petrol cap
does it need a breather in the cap or something
or
is it ment to be pressurised
thank you
Posted on: 2007/12/22 2:11
Re: running efi engine with standard carbi fuel tank and surge tank
From perth airport
my 180sx would have a lot of pressure when opening on a hot day after running
and my bros corrollas fule tank imploded one day at the drags lol
hope that helps some how
Posted on: 2007/12/22 4:06
perth airport parking
Datsun 1200 ute A14
From Sydney, Australia
no..there should be no pressure. late model cars have a line from the top of the fuel tank to the engine bay, that goes through a carbon cannister, and feeds fumes into the engine at vaccuum.
1200 tanks should have a breather to atmosphere. you can't rely on the cap.
Posted on: 2007/12/22 6:34
any ideas any1
dont realy want to run a canister
so is it dangerous???
should i leave it loose???
Posted on: 2007/12/23 3:23
Posted on: 2007/12/23 3:24
has any1 done this before???
did you run a breather???
And where???
thank you
Posted on: 2007/12/23 10:44
From Melbourne, Australia
i had this problem with my ute.. never solved it... was going to drill a breather hole in the filler cap but never got around to it
there is a breather system on the tank which goes up into the guard, you should be able to access it through the panels in the tray. maybe it's blocked, or maybe just inadequate. tank should be able to breath one way or another
Posted on: 2007/12/23 11:04
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
the breather hoses are blocked or missing. A non-EFI system has less fuel leaving the tank at a time, so you may need to upgrade the diameter of the breathers. Make sure they are still connected. All in the factory workshop manual, and discussed before (with pictures I believe:
In the wiki:
Fume Control: Datsun 1200 wiki
Posted on: 2007/12/23 13:11
From Okinawa, Japan
Every car I've ever put gas in here in Japan does this, so it can't be all that bad. I thought it was wierd at first because I've never noticed it in the states, but when every car (except diesels, for some reason) over here did it I just got used to it.
Posted on: 2007/12/23 13:26
