welding
got an arc welder for christmas, but wondering if i can weld exhaust hangers with it? or even exhausts? doesnt have to look pretty but functional.
anything else they come in useful for welding?
Posted on: 2007/12/25 2:13
Re: welding
From perth airport
good luck there not ment for that you need a mig
Posted on: 2007/12/25 3:23
perth airport parking
Datsun 1200 ute A14
Re: welding
From Tasmania
You can use them to do Exhausts it just depends on your welding skill and the material you are welding.
Posted on: 2007/12/25 3:42
Proud member of " The Tasmanian Datsun Owners Group"
Re: welding
From Okinawa, Japan
Takes a little practice but it can be done. I've used my cheapy arc welder to tack exhast together and get everything set up then bring it somewhere there's a mig to have it finished up.
Posted on: 2007/12/25 3:59
Re: welding
From Coondle, WA Australia
There is nothing wrong with an arc welder. I learnt to weld on one, and it just takes pratice to use them well. Yes you can weld exhausts with them. Hec thats all they used till migs became mainstream. ( I will confess, I am not much of a welder though)
I find the key to it is good quality rods, that are nice and dry, and thin. If my rods are a little old, i bake them in the oven for about 15 mins to dry em right out.
And i always have a play first on some scrap stuff so that I get the ampreage right.
Sure migs require less skill to get an arc, but you still need a steady hand, and praticse to get a good bead.
I guess I have a soft spot for my welder. It was my fathers that he bought in the early 70s, and it built most of the machinery on the farm. In saying that I also have a little gassless mig now that I use for the really fine stuff.
So in conclusion, yes the arc welder will do the job good enough. A mig can make an unskilled welder look better, and its eaiser on thin stuff.
Posted on: 2007/12/25 13:05
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: welding
From Melbourne AUS
i managed to weld my exhaust up with an arc and im the worlds worst welder.
if i can do it, so can you
happy welding
Posted on: 2007/12/25 13:53
1973 B110 A12
Re: welding
well ange, lloks like i might have a challenge for that title for you
worlds worst a series welder
Posted on: 2007/12/26 3:43
