1200 ute with R31 skyline diff
From Nyngan, nsw Australia
need some info on this...
What mod's are needed in fitting a R31 skyline disc brake diff to a datsun 1200 ute,
any help would be great
Posted on: 2008/1/3 22:50
Re: 1200 ute with R31 skyline diff
From Brisvegas, oz
you would need te diff to be cut down for starters then you would need a new rear uni to suit, im pretty sure that s all
Posted on: 2008/1/3 22:59
www.camerasplus.com.au
From Melbourne Aus.
Hmm shorten it...
add leaf spring mounting plates
and sort out the hand brake cable
search would revile more as this has been discussed may times
Posted on: 2008/1/3 23:04
From campbelltown (sydney) australia
you can use the standard ute leaf spring mounts just use u bolts.
Posted on: 2008/1/4 9:30
* caution, sunglasses must be worn to view my ca18det *
From Adelaide, SA the drift state
maddat has this exact setup bolt in.
Posted on: 2008/1/4 10:29
From Sydney (Carlingford)
Yeh, maddat do have it but for around $2500 it's not cheap.
although, if you had to find and buy a diff and then pay someone to do it all from scratch that wouldn't be cheap either.
I guess it depends on how much of it you can do yourself.
Posted on: 2008/1/4 11:48
From perth airport
yea i am looking at this too and price are all over the place i have heard prices as low 600 to shorten and as all the way up too the maddat diff ( im normaly a big fan of maddat but it seems too expencive )
coz a r31 diff should be cheap , under $500 ??? and shorten around a grand ??
$120 for the tail sharft
does any one think these price are off the mark ??
Posted on: 2008/1/4 12:37
perth airport parking
Datsun 1200 ute A14
From Perth WA
Well my super duper trade price to get a b/w shortened is $550. But that does NOT include welding on all brackets etc. You can get a Whole R31 for a coupla hundred.
Donno why everybody goes for these diffs... The LSDs are #### for em!
Posted on: 2008/1/4 12:46
Chris...
From Coondle, WA Australia
Well i guess the attraction for me was
1. right stud pattern (saving)
2. BW are common as muck, so parts are easy
3. gazillions of ratios available
4. keeps it in the family.
5. can cope with more torque than the 1 series will ever put out = almost unbreakable
6. for me since the 1k is so short, they had to machine both axles down, so the axles are now stronger than factory, so it really is unbreakable!!
sure you could cut down a commodore or falcon diff, but that wouldnt be right now would it!
Posted on: 2008/1/5 0:36
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Canberra
yeh standard LSD's are crap, but you can get good LSD's to suit or minispools for $80.
Posted on: 2008/1/5 3:05
