t50 gearbox in a kb10 is this the right cabel ???????
From perth airport
hey guys i have just put the a15 with the t50 gearbox in the thou coupe (kb10)
the tec section says it can stay cable
does any one have a pic of where the motor and gearbox meat , ( where the cable clutch should go ?
my car does not have a cable ( think it snapped ) and it has nothing where the cable should be held to the motor ?
where could i buy the parts from ?
or can i go hydraulic ?????????????
thanks
Posted on: 2007/12/30 23:20
perth airport parking
Datsun 1200 ute A14
Re: t50 gearbox in a kb10 ( help with clutch thingo)
From sydney
Dont go hydraulic, use a 1200 clutch cable, did I send you one? if not it may still be here.
Posted on: 2007/12/31 8:40
From perth airport
ummm nar i dont have one but thats cool just so i know wat to get ill be off to the wreakers when the shops open bloody holidays
Posted on: 2007/12/31 9:05
Datsun 1200 ute A14
From tasmania
if it a cable clutch before it would be easy to adapt a 1200 cluctch set up I did one to a 1000 the cable nomaly runs through the bellhousing if your box hasnt got the hole where the cable goes through just make a bracket and bolt it to the belhousing you need to modify where it come out of the firewall is diferent a 1000 cable is different there to if it was hydraulic the cluch fork maybe pushing not pulling
Posted on: 2007/12/31 9:14
From gold coast QLD australia
email sent
Posted on: 2008/1/1 2:04
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
From perth airport
hey guys is this the right cable?
ebay 1 day to go
Posted on: 2008/1/4 1:25
Datsun 1200 ute A14
From sydney
Yep, looks like the right from here.
Posted on: 2008/1/4 2:46
From Newcastle (NSW)
Yeah, right cable. The 1000 4-speed has a different clutch throw-out mechanism to all other a-series and uses a shorter clutch cable. I'm assuming you purchased the T-50 from Sidedraught...is that correct? If so, you should be right. Otherwise if its a strandard T-50 straight from a celica or T18 then you'll need to combine datsun and toyota parts to convert it to cable operation. Thats easier than converting to hydraulic. I find cable much smoother and maintenance friendly anyway.
Posted on: 2008/1/4 4:34
Racecar spelled backwards is racecar!
From perth airport
yea its sidedrafts old box
so ill bid away :) thanks for all the help
Posted on: 2008/1/4 6:27
Datsun 1200 ute A14
