reverse eye leaf suspension
Not too shy to talk
From Brisbane, QLD, AUS
Finally got to doing it...reverse eye leaf suspension....took a day of work and did it.....rear end sits good 3"lower and squats down when you boot it....not bad knowing it cost me $0 just a lot of fu$in around..I will upload pictures if someone could tell me how to post them on threads..........
PS It is looking mean with them 15"s on the back......
Posted on: 2003/5/8 12:56
u ask me why
I say why not
Re: reverse eye leaf suspension
Not too shy to talk
From south australia
How did you do it. Im about to do the suspension on my 1200, a write up and pics would be great. cheers
Posted on: 2003/5/8 14:01
Webmaster
From Lisbon - Portugal
Webmaster
Upload your photo to our photo album, copy the image url and the use the IMG buton.
You can use our test forum, for testing
daniel
Posted on: 2003/5/8 16:35
Keep them alive and sideways!
From NorCalifornia, up by Sac
Are you talking about flipping the rear leafs upside down? Been there-terrible ride. The "free" way to lower the rear & still get a stock ride is to relocate the axle above the leafs. In front, find F10 struts(fatter & tighter coils) and cut out 2 or 3 coils and/or heat the coils till they drop to desired height. Beware, if you go too low up front, you won't be able to turn! I found some 12" rims for the front and 13" in the rear. I've been trying to scan photos but don't know how. Anyway, this is what I did back in'88. I'm now trying to find another sedan.
Posted on: 2003/5/9 23:40
Not too shy to talk
U can finally check the pics of my car after lowering ...
why120y1
why120y2
why120y3
more in members section under why120y...
Posted on: 2003/5/11 2:55
u ask me why
I say why not
Did you flip the whole set of leafs over
or just one?? or two
please explain??
and wot have you done to the front suspention??
Posted on: 2003/5/11 3:33
Not too shy to talk
Back:
only reversed the bottom 3 leafs and leaving the main(longest)as it is..............
Front:
It had 4 coils cut out ... another example what happens when beer and angle grinder come together..........it is getting replaced by stanza struts...........
Posted on: 2003/5/11 6:53
u ask me why
I say why not
From Sydney, Australia
That looks pretty mean. You need to flare the front guards a bit, and get some nice wide wheels under the front too. A bit of a polish-job for the paint. Then you are ready for some cruisin..
Chris
Posted on: 2003/5/11 9:13
I like it, it looks cool,so you reversed the eyes on the leaf springs, I got mine decambered 2 inches low, I was told I can add the extra inch(lower it 1 more inch) by reversing the eyes,but first I will finish my front, do not want to end with the front taller than the rear. You mention 4 coils, what about your shocks, are those hitting bottom now? ( I read you are getting Stanza's front suspension) . I will have to flare the front and rear, because I use 13X8 wheels w 215/50/13's, but the end result will be monstruos. I plan 235/50/13 for the rear.
Jaime
Posted on: 2003/5/11 10:52
From Canberra, Australia
HAving different diamter wheels on your car is defectable, so look out for the cops.
How is your clearance on the back?
Posted on: 2003/5/11 14:34
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
