Browsing this Thread:
1 Anonymous Users
Re: Brake upgrade without track increasing. |
From Brisbane, Narangba
Yeah Anges setup is what im after. Only 7mm either side is excellent.
Posted on: 2008/1/13 3:35
From Adelaide
i also got the s13 on 120y set up.. great set up and can pull up a ca18det on 15psi very fast :) hehe not that i tried but they dnt work for 13inch rims wwithout spacers
Posted on: 2008/1/13 4:42
From Mandurah, Western Australia
The track on my 1200 coupe is 25mm extra on back and front, which is legal.
On the front Stanza struts with Mitsubishi Colt 13 inch rims.
The rear has Corolla KE55 Borg Warner Diff with Stanza Drum and also Colt Rims
Posted on: 2008/1/13 13:20
From Gold Coast Australia
Hey Dan, I have the sr20det brake setup also, but on sunny struts. But if you go for this I think you would be hard pressed to find a 14" wheel to clear them. espesially steelies, I tried heaps of 14" rims with no luck. I have 15" billets with only 5-7mm clearance of the rim for the caliper. Cheers Mitchell
Posted on: 2008/1/13 13:40
SR20DET Sunny for sale, click me for details
From Arlington, TX, USA
Quote: B210sleeper wrote: if 280zx struts are used with a proper spindle I recall it not widening the track very much, what were they... 350zx or something, i think they were 4 lug even.
It's from the 79-83 280ZX (maybe Fairlady there in Oz?). They will actually narrow your track by 8mm or so. Makes it much easier to fit deeper offset wheels, but harder to fit modern high-offset wheels. FWIW, the 280ZX brakes have bigger rotors than the S13 stuff I see mentioned above.
Posted on: 2008/1/14 2:08
1973 Datsun B110 Coupe (A15/5spd) 1977 Datsun 280Zed (5.0L/5spd)
From Burbank, CA
They're HUGE! with an A15 you'd have to try to fade them.
I can't complain a bit about my setup, you need 14"wheels, I got a matching set of 280zx wheels in the 14" size and it took a little bit of grinding to get then to clear my calipers, nothing major.
I wonder if my bump steer adjuster spacer is too thick, but other than that it's wonderful, adding the really stiff strut brace did wonders too.
but it looks nothing like stock, but it's all pretty well hidden.
There's also a super brake kit for the 280zx, I don't think they fit in 15" wheels even.
Posted on: 2008/1/14 6:22
|||\ 81 KPB310 /|||
280zx strut would be longer and run the bigger coils that wouldn't fit the 1200 strut tower id assume????
The S13 conversion is seeming like the easiest considering i can do all the machining myself.
Posted on: 2008/1/14 6:54
From Canberra
280zx needs new spring perches/coilovers. But they are shorter than stanza etc. I've got a set here I'm thinking about using instead of the stanza struts... but soo much effort :P
Posted on: 2008/1/14 7:15
From Burpengary
bit off topic but I have a full SR20DE brake setup sitting in my garage that I have Absolutely no intention of using. F+R hubs, rotors and caliper, lines, some handbrake cables, maybe pads not sure. I bought them on a whim off here but have gone a very different route indeed... if someone wants them make me an offer
Posted on: 2008/1/14 9:01
From Burbank, CA
The 280zx struts require coilovers or changing the spring perches, camber plates.
it's a bit involved, but well worth it.
Posted on: 2008/1/14 15:42
|||\ 81 KPB310 /|||
