earles oil cooler adapter
From perf
ok so i have found what i need but a search on the net has not revealed where i can get one except from earles in the uk. is there somewhere in oz you can get these?
Posted on: 2008/1/22 2:51
Re: earles oil cooler adapter
From Burbank, CA
those things are universal, there is SAE Ford, SAE Chevy and Metric, more or less.
A lot of em come with all 3 types of screw in adaptor.
I think I used a ford type one, but don't remember now, it has to do with what oil filter thread your car has.
Posted on: 2008/1/22 2:53
|||\ 81 KPB310 /|||
From perf
how can they be universal when oil filters come in different o-ring diameters and thread sizes?
Posted on: 2008/1/22 3:07
Because there's really only a few different popular combinations. Datsun A-series engine uses the same thread and o-ring diameter as Ford 'F1' Filter. So you use the Ford Universal adapter. The Ford filter is larger diameter on the outside, so you can use the smaller o.d. Nissan filter on the Ford adapter.
Posted on: 2008/1/22 3:42
From Burbank, CA
Or if you have space use the bigger filters ;)
Posted on: 2008/1/22 4:00
|||\ 81 KPB310 /|||
From Brisbane
http://www.earls.com.au/index.php
Sandwich plate assembly will cost you about $60 and an oil cooler approx. 12" x 4" is about $250.
The one I have for sale not appealing?
Posted on: 2008/1/22 4:54
Think outside the 'circle' it's boring.
From perf
all i need is the sandwich plate and i assume you would like to sell it as a complete kit.
thanks for all the info
Posted on: 2008/1/22 5:13
From Burbank, CA
if you're doing an oilcooler setup, you really want a check valve to keep the oil from draining out.
They're not commonly used for some reason, but i wouldn't have a cooler without one.
and a thermostat of course!
Posted on: 2008/1/22 5:26
|||\ 81 KPB310 /|||
From perf
it is for an oil cooler for a turbo set up that is going to get a hard time but also show quality. so it is going to loook nice.
Posted on: 2008/1/22 5:29
From Burbank, CA
relocating the filter too?
Posted on: 2008/1/22 5:34
|||\ 81 KPB310 /|||
