A series Autos trannys?
Hello dato owners ,
have a question for you guys , please
the datsun a12 a14 a15 , are all the same block?
This motor was avialable in the 1200 sed wag, 120y ,sunny, c20 van ectra ectra
They came with an auto in the 120y what kind of box was this , datsun ,borg warner ?
these where a 3 speed,
Is there a 4 speed auto avialable , maybe a later one of another motor can bolt on?
thanks for any help guys ,!
Posted on: 2003/5/13 13:16
Re: A series Autos trannys?
From Melbourne, Australia
what you said was all correct, not sure who makes the box, datsun i guess, i doubt borg warner (thought they made some of the diffs)
and highly highly doubt youll get a 4-speed auto
but hey, maybe someone else will know better than me, im just trying to give you a quick response
Posted on: 2003/5/13 13:21
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanks for the response 1200R,
some ov us suzuki sierra dudes are using these reliable little donks with the auto box ,just trying to gather more info ,the auto works wonders on extreme terrian .
But an overdrive would come in handy.
Thanks agian!
Posted on: 2003/5/13 13:32
sounds cool, are you going for the a-15's for the extra torque?,
why wouldn't you use the manual box?, i dont understand, we have a manual landcruiser and dont understand how people can 4wd in autos without engine breaking!
my bro is actually thinky of getting a suzuki and putting a CA18DET in for a bit of spice, any of the dudes done that converion?
I met a bunch of suzukis when i was rallying one day and they had some awesome cars, one was full space frame with fibre panels, one had SR20DE, very cool stuff
but hey what was wrong with the original 2 strokes?
Posted on: 2003/5/13 13:38
1200 Coupe Rallycar
From sydney australia
the best way to get a late model 4 speed auto is to get the jatco auto out of a r31 pintara,& use the bell housing from an a series auto.the autos are all jatco's,& the auto originally in my sunny is huge.
Posted on: 2003/5/14 1:48
From Stone Age somewhere in U.S.A.
early A series up to 1973 if I remember correctly used an automtic trans made by Borg Warner, then Nissan switched to one made by JATCO, stands for Japanese Automatic Transmission COmpany.
JATCO was a joint venture between Nissan and Mazda, both owning 50%.
the Borg warner unit and the JATCO unit were both 3 speeds, out of the 2 the JATCO is a much better trans. the Borg units would self destruct as you drove them, where as the JATCO unit was/is very similar to a Ford C4 and almost bullit proof, the only thing that seems to go wrong with them is that the vacuum modulator diaphram ruptures and ATF gets sucked into the intake manifold, causing them to not shift right and the engine to billow clouds of oil smoke.
as far as I know of, there was not a 4 speed auto available for the A series. 4 speed autos didn't show up until the mid 1980's, by then Nissan had stopped using the A series in any great numbers to make it profitable to do the design and engineering
Posted on: 2003/5/14 7:14
Thanks Guys,
doing somone elses homwork you might say ,But the theory behind the 3 speed jat and the four speed jat from pint sounds good i'll do some scroonge work at the wreckers, we have quiet a few wild zooks in the club , comodore v6s , 4azg or somthing super charged mr2 motor ,the guy im chasing this for has the a14 , my zook is based on a Range rover chassis 3.5 alloy v8 still biulding hehe. I'll let yas know how it goes!
Thanks agian.
Larry.
Posted on: 2003/5/14 13:27
From Canberra, Australia
In Canberra there was a guy with a 13B in a suzuki sierra (Umm samurai, I think in US). It was converted to RWD only and it wasn't turbo...
Was wierd when I saw it pull into the servo... I was looking around for an RX3 or RX7 etc... Then one of the blokes I was talking to said that it was the suzuki. And sure enough, it was... Weird...
Posted on: 2003/5/14 14:58
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Nope. There were two kinds of A12 blocks (70-73, and 74 up). The A14/A15 is a taller block than the A12.
All use the same transmission bolting pattern.
Posted on: 2003/5/15 8:10
talking bout weird cars
i saw a magna with "awd" written on the side, on the road today, tried to see a diff at the back but couldnt really tell
ive heard rumors of these cars but are they actually being sold now?
Posted on: 2003/5/15 10:49
1200 Coupe Rallycar
