(1) 2 3 »
has anyone done a 4link suspension in a coupe?
From Taupo
Wanting to know if anyone has done it and if they have plans if someone has...
Posted on: 2008/2/3 3:21
Re: has anyone done a 4link suspension in a coupe?
From Burbank, CA
I think there may be 1 or 2 that have, more likely is they swapped in an IRS rearend, for all the work changing from leaf springs to coil springs and 4 link.
Posted on: 2008/2/3 6:18
|||\ 81 KPB310 /|||
From Christchurch NZ
Quinn Has a four linked Hilux diff in his 1200 2 door sedan.
Posted on: 2008/2/3 7:25
Forced Induction!
From Taupo
Any help what so ever on this subject would be great. heard a couple of ausi's have done this and if you or you know of anyone that has. Tell me all....
Thanks
Posted on: 2008/2/5 5:05
From Taupo New Zealand
It has been done in NZ many times. I thought about doing it but ended up buying some JTS leaf springs and Konis from a fellow forum member and they work a treat. What are you trying to achieve? Is it for a race car?
Posted on: 2008/2/5 5:24
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Sydney, Australia
I did it in my sedan.
We didn't make plans for other people to follow,
I wouldn't recommend it, and I wouldn't do it again if I was building up another car.
Posted on: 2008/2/5 7:17
Have you any idea what those JTS springs are worth new?
Posted on: 2008/2/5 7:20
Can't remember exactly but from memory they were around the A$400-450 mark. Could be more now though that was a few years ago.
Doesn't seem cheap but when you consider the costs of four-linking: 2 coil springs, 10 rod ends, tube and other materials and welding and cutting consumables, not to mention time which I think people forget the value of (I know I do) they start to look pretty good value!
Maybe the four link is a better system for outright performance I don't know but a lot of quick cars still run leaf springs.
Posted on: 2008/2/5 8:22
1970 1200 coupe A15
1978 B310 SR16VE
From Brisbane
yerr mark bourne's 8sec ca ute still runs leaf springs
Posted on: 2008/2/5 8:56
From South East QLD
What are you setting the 4 link up for ?
Drag or circuit racing or Street , ?
Iam using a SATCHELL 4 link , with leaf springs still for circuit racing , but iam going to change over to a coilover shock and add a watts link soon ,, For Drag racing the CALTRAC Links on leaf Spring have been proven to work very well ,, But not for Circuit racing ..
Posted on: 2008/2/5 9:57
(1) 2 3 »
