Revoving Gearbox Crossmember Mounts
From Wagga Wagga, NSW
Gday Datsun1200er's im in the process of removing the a series 56a box mounts from the tunnel and decided bes to ask the most appropriate way to do it ? any help much appreciated
Jake
Posted on: 2008/2/22 7:55
Re: Revoving Gearbox Crossmember Mounts
From Christchurch NZ
That can be quite ticky. I tried to use a spot weld removing tool from underneath, but I couldn't get the angle right. So I tired drilling them out, with a normal drill and made a hell of a mess.
Posted on: 2008/2/22 9:06
Forced Induction!
From Southern Highlands, NSW, Australia
Oxy? Then use a grinder to neaten it up. Thats how we did it.
Posted on: 2008/2/22 10:20
'72 1200 sedan hillclimb/supersprint car
From Tamworth , NSW
reciprocating saw and grinder. they are pretty thin.
Posted on: 2008/2/22 23:36
From Canberra
Ask pigdog, I got his ones after he removed them and they werent damaged at all.
Posted on: 2008/2/22 23:38
From Okinawa, Japan
Used a spot weld removal drill bit with a 90 degree drill. Worked great.
Posted on: 2008/2/23 2:14
