Thanks Burt. it was a good suggestion & helpful to read up on it.
I knew the cornering example of one wheel turns at a higher rate then the other but I didn't think it affected the axle rotation rate while not loaded (not sitting on ground) & not breaking free from the other axle, always good to learn something new.
If anyone care this was an interesting read on differentials:
http://www.houseofthud.com/differentials.htm#open%20diffphunkdoktaspok wrote:
"So did you take the time and calculate what centre you have yet? maybe it really is 3.9-1 maybe its just a rough guess.
I dont see any logic in asking how to do something and then just taking a rough guess."
As I said "I pulled the diff" it's stamped right on it next to the little Nissan logo 39.10. Logic would dictate that's the correct ratio, seeing that it came out of a 1200 coupe whose spec book (factory manual) say it standard w/a 3.90 ratio. That seems pretty logical to me......but I could be wrong, I have been before.
